Searching for UA spareparts is a pain.
I hope i get one of keuks manifolds.
Did anyone try the cp manifold? Will it fit on the GT160 without problems?
I struggle because i won‘t spend the money for it and a cp carb, only to find out its not that good. I heard its tricky to tweak the cp carp.
Thank you guys in advance.
vor 22 Stunden schrieb freddykrger:
a friend of mine uses a manifold made out of the lc-cooling hose from whatever scooter or motorcycle for his cp carb. It works. Only the carb needs a little support.
Yes they sale parts like that on the spanish websites:
540817705_Capturedecran2019-03-09a09_12_05.thumb.png.921a137fdb4c277ba719fba842ff7bd3.png2143866187_Capturedecran2019-03-09a08_24_35.thumb.png.03b501921676df7d5ca06cba45c65be6.png
I made printed parts too to fit on the original manifold. But we are still struggling with the overhangs on the printing process resulting in bad surfaces
image-2.thumb.png.e3ce5ffb759cb60f56f249adb39ea3d5.pngimage-1.thumb.png.d44cf80c18271325e7da6bf7bcbe4d5d.png
thumb_IMG_4625_1024.thumb.jpg.6a66ff5d5f0985a8c70923f6af41b7d4.jpgthumb_IMG_4619_1024.thumb.jpg.7bb53ca221d92c4add4de8266a68da98.jpg
That‘s a good idea. Maybe i‘ll find something in one of my „spareparts-maybe-i-need-it-one-time“ boxes. Thank you!
@keuk:
Thank you. Maybe i find what i need in spain.
First i wait for your manifold. This looked the best yet and the VHST is my favourite carb.
I know the problems that the printer can have. At work our testfield got a really expensive one. But often the surface is crap... hours of hours for nothing...
vor 45 Minuten schrieb keuk:
What is the recommended squich on the 160GT ?
What is the 0,8mm Rüstand Alex was talking about ?
I think 1,1mm to 1,2mm will be good.
The  Rüstand is short for Kolbenrückstand that means how many mm from the upper edge of the cylinder are left if the piston is in upper dead point.
I hope my english is correct.
I got it ! Thanks that is clear.
By the way, my guy has updated the corebox and the pattern and should be ready to launch new models of the manifold on saturday ;-).
  • Like 3
New 62mm piston received, back to the 128° for intake
About the timings. Do you have this machining mark in the transfert port ? If I use the line of the red arrow, I have 120/150 with a 0,5mm gasket. As the machining mark is not that deep I wonder if the 120 are really accurate.
240796123_Capturedecran2019-06-21a11_43_03.thumb.png.b44849a45654df8f90a8d8522589f4fb.png
As Alex suggest, I will increase the exhaust height to reach 160° to increase the blowdown, do I enlarge the flange to 62% instead of 50% too?
1131726013_Capturedecran2019-06-21a11_40_05.thumb.jpg.30b1f584d1de617d67012224bd52b8fa.jpg
vor 23 Minuten schrieb keuk:
imageproxy.php?img=&key=ba1323ba10a7ed48
The 120° are accurate yes and no - because there is no volume behind the small slot. If you grind the transfer port to have there an evan surface...
regarding the exhaust port:
I know that's a pain, but to minimize the risk of  to go too far, go wider first, do some testing, go higher, do some testing.
Hallo Wheelspin,
vielen Dank für die Antwort. Dem spanischen Bild nach sieht die Schaltraste dann der 160GS/180SS am nächsten
https://www.sip-scootershop.com/DE/Products/87031000/Schaltraste+FA+fur+Vespa+160.aspx?_country=DE4B2F82-D7AF-4AFD-BDE2-C726EF770AEF&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=87031000&dfw_tracker=40504-87031000&gclid=CjwKCAjwsIbpBRBNEiwAZF8-z2xw2N_MVC3YHU6NQXLYEOQ5-Ejrp6MdWgihnh8YTsJA4X9UiR2vARoCFVIQAvD_BwE
Dann fahre ich mal zu Scooter Center mit meiner alten Raste und mache einen Vergleich...
Hallo Wheelspin,
Lass mich bzw uns aber bitte wissen wenn eine von nem anderen Modell passt. Danke!
Am 18.5.2019 um 21:05 schrieb ChrisW.:
Hallo, hätte eine Frage zur Kupplung der 160GT. Ich weiß dass sie einen eigenen Korb haben und die Beläge der PX 200 passen sollten. Leider habe ich dass Problem, dass die Kupplung nicht ganz trennt, daher sobald der Gang eingelegt ist, hat sie Vorwärtsdrang. Ich habe nur die Beläge getauscht, auch schon versucht neuer PIlz, anderer Deckel usw. Nachspannen bringt nichts...Im ausgebauten Zustand trennt sie ganz normal.
Gibts da verschiedene Zwischenscheiben, oder könnte ein Spacer helfen.
Vielen
Dank für die Hilfe
Ich fahre nach langem Probieren die Beläge der GS3 mit den Original Trennscheiben, die auch dünner sind, als bei PX und co.  und das funktiert endlich.
Am 25.5.2019 um 13:41 schrieb salvatorescilaci:
Hola in die Runde,
welchen Auspuff fahrt ihr am liebsten auf der 160GT? Repro und ausgebrannter Original sind mir zu laut. Weiß nicht ob’s am Ausbrennen liegt, aber der originale Klang ist auch mit dem originalen nun nicht mehr gegeben. Nervt innerhalb geschlossener Ortschaften tierisch.
Hätte gerne etwas dezenteres. Gibt’s Alternativen? Ist der angepasste SIP Road leiser?
Danke für Euer Feedback!
Salva
Ich hatte erst ein Repro aus Spanien von scooterclasico.es), der einfach nur laut war, vermutlich wegen des dünnen Blechs. Dann habe ich mir so einen von Megadella umbauen lassen. Leider genauso laut und keinerlei Leistungsverbesserung.  Durch Glück habe ich einen originalen (nicht ausgebranten) auftreiben können. Und der ist jetzt schön vom Klang her und nicht zuuu laut. ;-) Allerdings ist der schon etwas geschweisst und ich habe nur ein paar mm Platz zum Hinterreifen. Weiss jemand, ob die vom Scootercenter die gleichen sind, die auch scooterclasico vertreibt?
Am ‎07‎.‎07‎.‎2019 um 14:10 schrieb freddykrger:
wie ich vermutet habe passte die Schaltraste für die GS160/180SS auf meine MV160.
Gekauft bei SC https://www.scooter-center.com/de/schaltraste-oem-qualitaet-4-gang-vespa-gs160/gs4-vsb1t-ss180-vsc1t-4350161?sPartner=google-shopping-de&gclid=CjwKCAjwvJvpBRAtEiwAjLuRPcx1oyPjxu1fZE4fK6nwsJEEWI-64prDrfHKijCnOoCoD_OGOap9yxoCeWkQAvD_BwE
Die ist von FA-Italia. Heute eingebaut und funktioniert einwandfrei.
Andreas
Bearbeitet von Andreas-DU
  • Like 3
Am 14.6.2019 um 21:21 schrieb keuk:
Hi,
do you have a jetting suggestion for that setup with SIP Road?
A friend of mine has that carb kit on his GT and is in a little trouble with jetting.
Thank you.
By my side I haven’t struggled with the dellorto carburetor yet. However soon or later I will have to, as the series is almost ready ! Yeah !
  • Like 3
vor 1 Stunde schrieb keuk:
Looks pretty good. So I need to get my engine ready... yeehaa
    • Ich hab grad keine Ruhe, um das alles detailliert darzustellen.   Wenn Du die Vape oder zumindest den Vape Regler mit ner massefreien ZGP verbaust, ersetzt Du den Originalen Regler. Lichtschalter bleibt. Blinkerrelais muss ersetzt (AC nach DC) werden, Hupengleichrichter fliegt raus. Wichtig, die Rückleitung der Hupe muss dann auf Masse    Lima Blau plus (zwingend bei massefreier original ZGP!) Ersatz für das schwarze von der Lima auf den Vape Regler Eingang (braun?). Von da den Ausgang rot auf grün/grau und schwarz auf Masse, Batterie kann entfallen oder wird mit eingebunden.    Das ist jetzt alles aus dem Kopf vom letzten Umbau.   Ohne Batterie brauchst kein Relais. Mit Batterie würde ich das umbauen.   Das übersteigt jetzt etwas meine Zeit. Grob gesagt musst Du dann mit dem Zündschloss Umbau mit einem Relais ein geschlossenes Kontaktpaar grün auf Masse bei Zündung ein öffnen und mit nem weiteren Relais oder unabhängigem Kontaktpaar Klemme 30 (plus) schließen, das ist dann nicht mehr ganz so trivial, nen Plan dazu malen kann ich aktuell nicht.   Blinkerrelais hab ich reichlich liegen als DC, die gleichen wie bei SC für 10 Euro. Nur deutlich günstiger.   Ducati ZGP Massefrei plus Vaperegler ist aus der Erfahrung raus bei viel Stadtverkehr nicht in der Lage, die Batterie immer voll zu laden. Auf langen Strecken gehts.
    • Verkaufe meine Falc Gangräder mit Falc Nebenwelle und Falc Kickerritzel ohne beschädigungen. Alles meins und nur hier!!   Preis: Euro 450,- Standort: AUT, Kärnten Villach. Versand möglich.    DRT Cobra Primär 60x22  Preis: Euro 100.-  Standort: AUT, Kärnten Villach. Versand möglich.
    • ..hat zum Glück immer nen Löffel dabei
    • Hallo, Batterie ist zwar verbaut, aber die wird im Moment mit dem kleinen BGM Regler nur geladen für Zigarettenanzünderbuchse ( zum Handy laden)bzw. Komressorhupe....... Schaltplan ist mit Hupengleichrichter. Kann ich den Lichtschalter von der Lusso so behalten oder muss der auch neu oder geändertwerden? Wenn ich das richtig sehe, bekommt der über das graue Kabel doch im Moment den noch AC Strom? Sorry, aber ich bin kein Elektrik Experte....
    • Ist doch im Link zwei Beiträge weiter oben.
