Searching for UA spareparts is a pain.
I hope i get one of keuks manifolds.
Did anyone try the cp manifold? Will it fit on the GT160 without problems?
I struggle because i won‘t spend the money for it and a cp carb, only to find out its not that good. I heard its tricky to tweak the cp carp.
Thank you guys in advance.
vor 22 Stunden schrieb freddykrger:
a friend of mine uses a manifold made out of the lc-cooling hose from whatever scooter or motorcycle for his cp carb. It works. Only the carb needs a little support.
Yes they sale parts like that on the spanish websites:
540817705_Capturedecran2019-03-09a09_12_05.thumb.png.921a137fdb4c277ba719fba842ff7bd3.png2143866187_Capturedecran2019-03-09a08_24_35.thumb.png.03b501921676df7d5ca06cba45c65be6.png
I made printed parts too to fit on the original manifold. But we are still struggling with the overhangs on the printing process resulting in bad surfaces
image-2.thumb.png.e3ce5ffb759cb60f56f249adb39ea3d5.pngimage-1.thumb.png.d44cf80c18271325e7da6bf7bcbe4d5d.png
thumb_IMG_4625_1024.thumb.jpg.6a66ff5d5f0985a8c70923f6af41b7d4.jpgthumb_IMG_4619_1024.thumb.jpg.7bb53ca221d92c4add4de8266a68da98.jpg
That‘s a good idea. Maybe i‘ll find something in one of my „spareparts-maybe-i-need-it-one-time“ boxes. Thank you!
@keuk:
Thank you. Maybe i find what i need in spain.
First i wait for your manifold. This looked the best yet and the VHST is my favourite carb.
I know the problems that the printer can have. At work our testfield got a really expensive one. But often the surface is crap... hours of hours for nothing...
vor 45 Minuten schrieb keuk:
What is the recommended squich on the 160GT ?
What is the 0,8mm Rüstand Alex was talking about ?
I think 1,1mm to 1,2mm will be good.
The  Rüstand is short for Kolbenrückstand that means how many mm from the upper edge of the cylinder are left if the piston is in upper dead point.
I hope my english is correct.
I got it ! Thanks that is clear.
By the way, my guy has updated the corebox and the pattern and should be ready to launch new models of the manifold on saturday ;-).
  • Like 3
New 62mm piston received, back to the 128° for intake
About the timings. Do you have this machining mark in the transfert port ? If I use the line of the red arrow, I have 120/150 with a 0,5mm gasket. As the machining mark is not that deep I wonder if the 120 are really accurate.
240796123_Capturedecran2019-06-21a11_43_03.thumb.png.b44849a45654df8f90a8d8522589f4fb.png
As Alex suggest, I will increase the exhaust height to reach 160° to increase the blowdown, do I enlarge the flange to 62% instead of 50% too?
1131726013_Capturedecran2019-06-21a11_40_05.thumb.jpg.30b1f584d1de617d67012224bd52b8fa.jpg
vor 23 Minuten schrieb keuk:
imageproxy.php?img=&key=ba1323ba10a7ed48
The 120° are accurate yes and no - because there is no volume behind the small slot. If you grind the transfer port to have there an evan surface...
regarding the exhaust port:
I know that's a pain, but to minimize the risk of  to go too far, go wider first, do some testing, go higher, do some testing.
Hallo Wheelspin,
vielen Dank für die Antwort. Dem spanischen Bild nach sieht die Schaltraste dann der 160GS/180SS am nächsten
https://www.sip-scootershop.com/DE/Products/87031000/Schaltraste+FA+fur+Vespa+160.aspx?_country=DE4B2F82-D7AF-4AFD-BDE2-C726EF770AEF&gpc_origin=shopping&gpc_feed_alias=de&gpc_pid=87031000&dfw_tracker=40504-87031000&gclid=CjwKCAjwsIbpBRBNEiwAZF8-z2xw2N_MVC3YHU6NQXLYEOQ5-Ejrp6MdWgihnh8YTsJA4X9UiR2vARoCFVIQAvD_BwE
Dann fahre ich mal zu Scooter Center mit meiner alten Raste und mache einen Vergleich...
Hallo Wheelspin,
Lass mich bzw uns aber bitte wissen wenn eine von nem anderen Modell passt. Danke!
Am 18.5.2019 um 21:05 schrieb ChrisW.:
Hallo, hätte eine Frage zur Kupplung der 160GT. Ich weiß dass sie einen eigenen Korb haben und die Beläge der PX 200 passen sollten. Leider habe ich dass Problem, dass die Kupplung nicht ganz trennt, daher sobald der Gang eingelegt ist, hat sie Vorwärtsdrang. Ich habe nur die Beläge getauscht, auch schon versucht neuer PIlz, anderer Deckel usw. Nachspannen bringt nichts...Im ausgebauten Zustand trennt sie ganz normal.
Gibts da verschiedene Zwischenscheiben, oder könnte ein Spacer helfen.
Vielen
Dank für die Hilfe
Ich fahre nach langem Probieren die Beläge der GS3 mit den Original Trennscheiben, die auch dünner sind, als bei PX und co.  und das funktiert endlich.
Am 25.5.2019 um 13:41 schrieb salvatorescilaci:
Hola in die Runde,
welchen Auspuff fahrt ihr am liebsten auf der 160GT? Repro und ausgebrannter Original sind mir zu laut. Weiß nicht ob’s am Ausbrennen liegt, aber der originale Klang ist auch mit dem originalen nun nicht mehr gegeben. Nervt innerhalb geschlossener Ortschaften tierisch.
Hätte gerne etwas dezenteres. Gibt’s Alternativen? Ist der angepasste SIP Road leiser?
Danke für Euer Feedback!
Salva
Ich hatte erst ein Repro aus Spanien von scooterclasico.es), der einfach nur laut war, vermutlich wegen des dünnen Blechs. Dann habe ich mir so einen von Megadella umbauen lassen. Leider genauso laut und keinerlei Leistungsverbesserung.  Durch Glück habe ich einen originalen (nicht ausgebranten) auftreiben können. Und der ist jetzt schön vom Klang her und nicht zuuu laut. ;-) Allerdings ist der schon etwas geschweisst und ich habe nur ein paar mm Platz zum Hinterreifen. Weiss jemand, ob die vom Scootercenter die gleichen sind, die auch scooterclasico vertreibt?
Am ‎07‎.‎07‎.‎2019 um 14:10 schrieb freddykrger:
wie ich vermutet habe passte die Schaltraste für die GS160/180SS auf meine MV160.
Gekauft bei SC https://www.scooter-center.com/de/schaltraste-oem-qualitaet-4-gang-vespa-gs160/gs4-vsb1t-ss180-vsc1t-4350161?sPartner=google-shopping-de&gclid=CjwKCAjwvJvpBRAtEiwAjLuRPcx1oyPjxu1fZE4fK6nwsJEEWI-64prDrfHKijCnOoCoD_OGOap9yxoCeWkQAvD_BwE
Die ist von FA-Italia. Heute eingebaut und funktioniert einwandfrei.
Andreas
Bearbeitet von Andreas-DU
  • Like 3
Am 14.6.2019 um 21:21 schrieb keuk:
Hi,
do you have a jetting suggestion for that setup with SIP Road?
A friend of mine has that carb kit on his GT and is in a little trouble with jetting.
Thank you.
By my side I haven’t struggled with the dellorto carburetor yet. However soon or later I will have to, as the series is almost ready ! Yeah !
  • Like 3
vor 1 Stunde schrieb keuk:
Looks pretty good. So I need to get my engine ready... yeehaa
    • Hallo zusammen,   letztes Jahr habe ich mir eine PX80 Lusso Elestart Bj 1993 geholt. Den Sommer über gefahren. Alles prima.   Dann: Plötzlich liegengeblieben, da sie nur noch in hohen Drehzahlen Gas angenommen hat. Das hatt eich während der Fahr gemerkt. Also: Frühzeitige Motorrevision (wollte ich eh machen). Heute war es dann so weit: Motor wieder eingebaut. Direkt angesprungen. Aber nach 300 Metern kündigte sich schon genau das Problem wieder an, weshalb ich liegengeblieben bin.   Was habe ich gemacht:   Lager neu Simmerringe neu Dichtungen neu Gummis neu Kurbelwelle neu Ölpumpenrad in dem Rutsch neu gefettet + abgedichtet Kupplungsbeläge neu Schaltkeuz + Schaltstange neu (Getriebe ausdistanziert. Entsprechenden Schulterring verbaut). DR 135 neu (der alte lief zwar, aber ich dachte mir: Komm, mach alles neu) Kühlrippen wegen des Zahnkranzes am Polrad bearbeitet Zündkerze neu (hab dieselbe geholt, die vorher drin war. Lief ja. NGK B7ES Zündkabel neu   Verbaut ist ein 20er Si mit Standard PX80 Bedüsung (bis auf die 104er Hauptdüse zum Einfahren). Luftgemischschreube hinten am Vergaser 2 Umdrehungen raus. Luftfilter ist gereinigt. Vergaser natürlich bei Revision auch mitgemacht (gereinigt und neu abgedichtet)   Habe die 3 Liter Gemisch Variante zum "Einfahren" gewählt, bis die Ölpumpe wieder Öl fördert. Daran sollte es aber nicht liegen.   Was genau passiert nach dem Anlassen?    Sie springt direkt an. Beim 2ten Kick. Batterie hat sich wohl entladen. Mit Elestart ging es nicht. Choke drin. Bisschen laufen lassen, da ja alles neu. Losgefahren. Choke irgendwann weg und dann stirbt sie schon ab. Kurz vorm Ausgehen Choke wieder rein. Dann gehts - aber nur in hohen Drehzahlen und gefühlt unrund. Im Standgas geht geht sie aus. Muss mit Gas am leben ghalten werden. Stellschraube oben am Lufi bringt nichts. Blebt so wie beschrieben.   Was kann es sein? Kann ja nur die Elektrik sein, oder? Da das Problem plötzlich aufkam (als ob ein Kabel keinen Kontakt mehr hätte), schließe ich eine plötzliche Veränderung am Vergaser nahezu aus. Ich hatte zunächst gedacht, dass der Motor irgendwo Fremdluft zieht, da ich 2 mal bevor es passierte (Zeitraum ca 1 Monat) das Standgas höher stellen musste, weil sie dazu neigte im Standgas auszugehen. Das kam mir schon seltsam vor. Noch seltsamer beim Zerlegen des Motors. Viele Schrauben waren gar nicht richtig angezogen. Viel zu laff.   Bin kein Pro. Ist meine erste Revision.    Was kann es sein?   Zündkerzenstecker? Defekt an der Zündgrundplatte? Defekt an der Elektronikzentrale?   Wie kann ich es rausfinden was es ist und entsprechend neu machen bzw. reparieren?   Vielen Dank für das Lesen. Dachte mir: Lieber viel Text als zu viele Fragen aufkommen lassen.   Merci vorab für Eure Tips.
    • Komisch das deine Pinasco Kulu für Sprint & Co anscheinend die flache Nabe alà Px auf der Grundplatte hat...
