vor einer Stunde schrieb freddykrger:
Hallo!
Hat von euch schon jemand das Schutzblech einer GT160 getauscht? Bzw passt das der Sprint?
Falls nicht muss ich wohl das originale aufarbeiten...
Sprint passt. Fahre ich selbst.
Can't wait for it...:-D
You run it with a Dellorto VHST right?
I would like to try the VHST and a Polini CP type 19 to 23..
Has anyone convert the MV160 engine to reed valve intake with a "normal" two port barrel? This could be also an easy solution.
In my case I don't looking for high numbers on the dyno. I'm probably okay with 10 to 12 at the rear wheel though.
Any suggestions for an exhaust for the original barrel that will support the low transfer timings with good torque at low revs?
I was wondering if the P125 piaggio exhaust would be an option. Instead of all the box type exhaust...
I’m back on the original setup, 19er, to see first how the 170cc and the Sip road work. The sip road has a volume close to a px125 I guess.
I have increased a little bit the inlet timing by increasing the piston squirt cut from 126 to 140 according to Bollag’s advices.
And timings are 120/150. And I have grinded a little bit the original manifold to make it match perfectly with the cylinder and the yellow spacer.
On the original setup I had a 84 main jet. I tried 92 100 110,  but in each case the full throttle is weird, bowwww and it’s a pain to  reach the maximun rev of the engine. Like if it was too lean. The rest of the power band is great .
I would like to solve this before struggling to find the good atomiser/needle matching on the Vhst.
Could it be the inlet timing or the exaust port too low ? Maybe the ignition ?
Intake duration should be fine but don't go crazy at this area. A small step could be a step too far. 140° is okay.
The exhaust duration is too small.
There is no blow down duration.
I would recommend 160 to 165 as a first step. Maybe, if possible, in combination with something below 120 transfer duration. Because the area of the transfers is not too small, the windows are huge compared to the barrel.
Do you guys also have this timings on the original barrel ?
Bearbeitet von keuk
I thought I would have lowered them a little bit increasing the barrel diameter to 62.
What is Rückstand ?
Bearbeitet von keuk
Am 8.6.2019 um 21:57 schrieb wheelspin:
About the reed valve I had this in mind too, but I didn't go further than a PLA prototype.
vor 41 Minuten schrieb keuk:
Nice idea but I'm talking about the position of the p-range SI carb.
U know the small reed valve system to use with the SI carb. As long as the engine is not completed I would like to fit a reed valve for SI crabs to the engine to run it with a normal barrel.
It's a pity to modify the original casings, furthermore you will have to change or modify the crankshaft. What about a M1X ?
Am 8.6.2019 um 06:08 schrieb keuk:
Arround 60€.
one for me too please. thanks :thumbsup:
Bearbeitet von digs
vor 8 Stunden schrieb keuk:
A few days ago I did a reed valve conversion to a SS50 engine but that's another story...;-)
In the end of the day it is what it is, an old and busted engine case... :-D
No, I don't want to spend too much money for a new barrel and I definitely not looking for a bunch of horses.
I will try your intake pipe first with a VHST or CP carb.
Btw I'm looking for an air mixture screw for the original UA carb. Are there the dimensions around? The one of my carb was totally destroyed...
This guy has probably the part:
https://www.milanuncios.com/motos-clasicas/ducati-dellorto-207314789.htm
Or this guy:
https://www.milanuncios.com/motos-clasicas/dellorto-ub-ua-ma-me-263328703.htm
By my side I think I will test another new piston, I have 142 inlet and 0,5 gasket and already at 120 for transfert port. I would like to figure put how it works first with near original diagrams before I try to improve something :-)
Bearbeitet von keuk
    • Das klingt für mich versicherungstechnisch spontan nach „Mietfahrzeug“. Wie hoch die „Miete“ dann letztendlich ist, ist ja egigs Sache.   Wie rollerbube sacht wird auch meiner Meinung nach eine wie auch immer geartete technische Legalität im jeweiligen Veranstaltungsland das mindestens ebenso große Thema sein.   Technische Schäden am Roller, die ein Gastfahrer verursacht, fallen mE in den privatrechtlichen Bereich, d.h. ein „Vertrag“ wäre vermutlich angebracht, aber evtl auch leicht anfechtbar, da egig ein Gerät zur Verfügung stellt, dessen Möglichkeiten und Eigenarten einen „normalen“ Fahrer schnell überfordern, sprich: bis durch Fahrlässigkeit etwas beschädigt wird ist der Weg weit. Und egigs Komponenten sind ja nun keine günstige Großserie. Wenn da was beschädigt wird ist man schnell in Preisregionen, für die es sich juristisch zu streiten lohnt.   …sind aber nur meine fuffzich Fennich.     d.
    • Schraube/Gewindestange reinkontern, bisschen in Form biegen, Spritschlauch drüber, fertich.
    • Verkaufe VNB 5T mit Cosa-Polini-Motor   Baujahr 1964   TÜV: Neu   Viele Eintragungen: POLINI 208, 30er Vergaser uvm.: Siehe dazu Bild mit Fahrzeugschein   Motor: (nur wenige 100 km alt) Cosa 200er Motor (Umbaukit Bremsankerplatte und Silentgummis) 24er Vergaser 60er Drehschieberwelle (KABASCHOKO), Ausßgleich über KoDi COSA 200er Getriebe 68/23 Cosakupplung mit Ring, Innen- zu Außenkorb punktuell verschweiß, 23Z DRT – Ritzel Polini 208 Grauguß, Auslass ein bisschen breiter und höher GS Kolben (Malossi-Layout) Kopf vom Polini Alu Auspuff SIP BOX 1 SEEEHR schönes Drehmoment und breites Band. Vmax lieg über 100km/h.   Leistungsmäßig ist hier sicher noch was drin (30er Vergaser ist ja schon eingetragen) und Auspuff gibt es inzwischen sicher Besseres.   Fahrwerk: Härtere Stoffi-Feder vorne Neuer Dämpfer vorne Bremstrommel vorne von SIP   Hinterrad 10 Zoll Vorderrad 8 Zoll     Rahmen: Sieht nicht toll aus, aber er ist gerade und hat keine Welle. Ich sag mal gewachsene Patina aus 25 Jahren Straßeneinsatz. Hohlräume mit Wachs versiegelt. Trittbrett vor längere Zeit erneuert und mit Owatol versiegelt. Trittleisten von V50. Lack: der stammt nicht von mir. Kam so aus Italien. Darunter könnte O-Lack sein.   TÜV neu ohne Mängel   Preis: 5200.-  Vor Ort kann über den Preis gesprochen werden. Aber ich verschleudere Sie nicht. Kann auch weiter da stehen bleiben, so sie gerade ist.   Wird nur abgemeldet verkauft.   85416 Langenbach
    • Hallo Zusammen,   grade festgestellt, dass der Pin an der seitenhaube abgebrochen ist.    was kann man da machen? Gibt es da Reparatursätze für? Bei sip hab ich nichts gefunden.    Auf der einen Seite ist er noch dran, reserveradseite ab.
