vor 14 Stunden schrieb px211:
It is s 5,75 inch daymaker, i used the one from bsb customs with homologation for Germany...
https://www.ebay.de/itm/LED-SCHEINWERFER-5-75-mit-Standlicht-Yamaha-Bolt-Raider-Stryker-SCR-950-Warrior/253190767218?hash=item3af3588272:g:7HcAAOSwXedZ1O3A
i used the Metal triangle, modified it a Bit and adopted it with the Original Support tabs of the og headlight.
no issues with speedo or Place
OK px211thanks a lot for the feedback... it seems the other DayMaker lights in 5.75" I have seen have no metal triangle with the 3 screws holes behind. There's many 5.75" Daymaker on the web, many seems to be from China without (E)uro certificate of homologation.. Do you have any other photos with Daymaker plug & metal triangle fixing on the handlebar (it seems the Daymaker cable & plug take a lot of space) ;)
vor 16 Minuten schrieb VULCAN SCOOTER SECTE:
the homologated version does in my opinion not differ from the china ones... but there are 2 different availible in black, one with the mounting points and triangular bracket and one without (most of the offered ones)
i do not have a picture with the open cover, but within the next weeks i can try to chatch some time to take a picture or 2...
i do have cutted the plug and used a smaller one ....but i did it more on practical purpose :-)
vor 1 Stunde schrieb px211:
Thanks a lot px211... in France even if we do not have TüV on our Vespas, cops can be picky regarding these type of parts ;) but I ride with a PX210 Malossi, Taffspeed pipe full beam H4/35W... but this new Harley type Daymaker attracks me only if there's a real difference compared to a crystal type front light...
  • 8 Monate später...
nachdem beim Wolpertinger grad nix weiter geht, die Kiste aber diese Woche an den Gardasee fahren darf/ Muss, waren ein paar Maßnahmen notwendig..
die erste: ein Gepäckträger :muah:... nein , würd ich mir nich hinschrauben, da fahre ich lieber 2x ... und nachdem der gepäckgurt von PLC nicht wirklich bei mir passt (kann nicht unter der Kaskade spannen), habe ich kurzerhand selbst material gekauft:
Gurtband 19mm, Planenhaken und ein paar verschlüsse zum klemmen....und dank Nähmaschine meiner mutter und einer Einweisung ins System, ging es dahin:
IMG_3084.thumb.JPG.918f970e5f55f554b4e9c5ab957a51e9.JPGIMG_3088.thumb.JPG.5f959eeee5bb8c79338cd72e9bf4ccad.JPGIMG_3089.thumb.JPG.a362cdacca4d6f7fa285be0da26788bd.JPG
Schlafsack funktioniert, Gepäckrpolle werde ich noch testen hoffe ich, sollte aber auch klappen und zur Not gehts wieder in den Mitteltunnel wie letztes Jahr.
ein zweiter punkt war dann noch ein nicht unerheblicher verlust von Getriebeöl, da habe ich mich dann zu einer 2. Entlüftung hinreissen lassen  mit einer Ringöse und Hohlschraube und einem Modellbaufilter... beim Reifenwechsel ist mir aber aufgefallen, das es eigentlich kein öl war, sonder Gemischt, welche es bei einem abgerutschten überlaufschlauf am vergaser schön nach unten verteilt hatte :wallbash:...aber am ende des Tages zählt, dass man wieder was gebastelt hat, auch wenn man es nicht braucht ;-)....
IMG_3091.thumb.JPG.baecfb20b93ce1e24eec96e7f402ba0c.JPGIMG_3092.thumb.JPG.4eb25541ec8e0c39a45271a2d0146e15.JPGPUXL1216.thumb.JPG.a4027b58a43f7af5407d0bcc4ea76f1f.JPG
nächsate woche gehts dann wieder am wolpertinger weiter
Nun ja, 1000km abgerissen zum energietanken an den Gardasee, auch wenn das wetter kacke war, es hat sich gelohnt :-D
defekte an meiner Kiste = 0, einzig die fucking vespatronic werde ich demnächst bei vollmond im wald verscharren... das Kack teil mag einfach meine Batterie nicht laden..... LED licht geht einwandfrei, aber der Tacho fällt dennoch aus und meine Batterie hat nach dem Wochenende die 10,2 volt erreicht :repuke:... nach nun 6000km Vespatronic werden sich unsere Wege zeitnah trennen
Nachdem meien Näh und nietkünste auch meine gepäckrolle gehalten hätten, das ganze aber scheuert und mir noch dazu meine frau 2 tage vor abgahrt über einen hacken gefahren ist beim rausfahren aus der garage mußte ich wohl oder übel auf einen gepäckträger umdisponieren....also fis zum Sip raus, aber leider war der flache FA nicht verfügbar, also dann halt den weiter abstehenden gekauft...und natürlich zuhause erstmal abgesäght, gekürzut und umgearbeitet :wallbash:
VZWB8652.thumb.JPG.7dd5696979976e7bea2bda587ee4f302.JPGIMG_3121.thumb.JPG.6e92151b612bdd35f73d670a3fc080d3.JPGIMG_3123.thumb.JPG.0f0ab87523157a55b227c15863af171e.JPG
jetzt hat er unten 1cm abstand zur Kaskade und hängt paralell zum beinschild
Abfahrt - FS-Ammersee-Zirlerberg-Brenner-Jaufenpass-Riva...
IMG_3152.thumb.JPG.59c152a0651a3b67ca90bdcba9558b4b.JPGIMG_3154.thumb.JPG.86ed78518f62925f01dbfc1cff734480.JPGIMG_3155.thumb.JPG.4562d3d44c49254db88fa1dfece2dfcf.JPGIMG_3160.thumb.JPG.9908e53766375f70a7128d9e1dce1fc8.JPGIMG_3179.thumb.JPG.ec317f1d1296b1cc952039e700237674.JPGIMG_3192.thumb.JPG.c5e823b513dd6d503f8987934283d897.JPG
gelaufen wie eine 1, keine defekte bis auf das Batterie thema, Kubelgehäuseentlüftung hat auch blendend funktioniert, furztrocken die kiste, aber die reifen haben mich wieder nerven gekostet...der conti twist ist eine KATASTROPHE bzw gemein gefährlich....
Bearbeitet von px211
ich bin Zeitgleich 900km Pässe geballert, Falzarego Pass, Jaufen-Pass, Pordoi....(bei Schnee und Regen)
Nach Aussage der Begleiter eher sportliche Fahrweise...(Fahre sonst 690 KTM Supermoto....) Bin kein einziges mal in Österreich/Italien gerutscht.. Fahre Heidenau K80SR, Ettaler-Sattel wars dann in Deutschland etwas rutschig.. Irgendwie ein anderer Straßenbelag.
Bearbeitet von vnb1t
Ich finde das schon witzig solche Touren mit solchen Fahrzeugen zu machen!
Und ganz ehrlich: Als ich mit der Duc in 09/2018 in Schottland im Dauerregen unterwegs war, hab ich mir (m)eine Vespa gewünscht. Das war so anstregend mit diesem Eisdielen-Hobel. Die Sitzposition ist furchtbar. Dazu stocksteif der Bock. Hab mir im Anschluß für solche Trips extra noch ne KTM ADV geholt.
100 km/h reichen mMn vollkommen aus. Muss natürlich etwas Leistung haben für den Berg, das Teil (Vespa) und vor allem halten. Und da habe ich irgendwie so meine Bedenken. Vollgas und durch habe ich mich damals nur bei meiner total originalen 80er PX getraut.
Schön Gepäck vorne und hinten. Dazu ggf. noch einen leicht und weich gepackten Rucksack und fertig. Im Handschuhfach und unter der Seitenhaube ist ja auch noch Platz.
Bearbeitet von DUCMAN166
vor 1 Stunde schrieb vnb1t:
ihr habt auch noch kurz vor abfahrt ne sammelbestellung im gleichen shop für regenoverals abgelegt oder?:muah:
pordoi is super schmierieg unten...auch wenns trocken ist...
vor 41 Minuten schrieb px211:
Kann man so sagen. :-D
vor 32 Minuten schrieb 12er:
Jetzt kann der Herr auch noch nähen
Was kommt noch alles :-D
elektrik bleibt mein tief schwarzes bermuda dreieck :whistling: mit grosser wahrscheinlichkeit
Am 20.5.2019 um 09:59 schrieb vnb1t:
Is ja lustig, uns habt ihr am Ettaler Sattel überholt ;-) nur meine Reifen waren mehr als glitschig und ich dachte ihr habt Superkleber drauf, so wie ihr da hoch gegast seid.. Grüße vom LL-PX 210
vor 32 Minuten schrieb Jumoko:
Der gute Conti twist :-D
vor 29 Minuten schrieb px211:
Ist der Reifen echt so übel bei Nässe? Hör das immer nur von Gott und der Welt.
Hab den Reifen auf drauf, fahr aber immer nur bei trockener Straße :gsf_tumbleweed:
vor 6 Minuten schrieb sinfonique:
Ich wollte es selbst nicht wahrhaben, ist aber so... absolut unberechenbar und nich annähernd Schräglage möglich... selbst bei langgezogenen landstrassenkurven zwickt man die backen zusammen... ich bin kein schlechter Fahrer und habe vor Nässe schon immer Respekt gehabt, aber mit dem Reifen artet das in Angst aus.... das Ding schmiert bei geringster Schräglage ...
vor einer Stunde schrieb Jumoko:
Ja genau das war ich :-D
vor 3 Minuten schrieb px211:
Krass wie man sowas dann aufˋn Markt bringt?! Da muss man doch bei diversen Tests schnallen??
doof nur das ich den vorne als 100/60/10 fahr und meines wissens nur den Twist in der Größe gibt.
Ich dachte zuerst es liegt an meiner alten dot der letzten Reifen... aber aktuell hab ich ganz frische drauf aus Ende 2018 ... aber genau das gleiche...
ich hsb 100-80 und 130-70 drauf, da is sie Auswahl bescheiden mit speedindex M bis 130...
Der Conti Twist Sport war ein schöner Reifen und auch im Regen gut: keine Ahnung warum sie den aus dem Programm genommen haben und nur noch die Regen-Katastrophe Conti Twist anbiedern!?!
Aber dafür gibt es jetzt ja den (für mich) Über-Reifen K80SR: Der kann einfach mal alles richtig perfekt!
@px211: Auf 130/70-10 gibt es den Heidenau K62 62M (130 km/h).  Der ist bei Regen absolut zuverlässig. Du kannst bei Dauerregen und absolut nasser Fahrbahn auf der Autobahn auch Geschwindigkeiten über 100 (GPS) km/h fahren, ohne dass Du Probleme bekommst mit Aquaplaning. Sportreifen auf 130/70-10 machen schon ab ca. 90 (GPS) km/h Probleme mit Aquaplaning bei absolut nasser Fahrbahn. Auch in nassen Kurven und beim raus Beschleunigen gibt der K62 einen starken Halt. Nachteil ist eine etwas schlechtere Abrollkultur als bei einem Sportreifen (Profil bedingt) und weniger Grip bei hohen Temperaturen.  Der Verschleiß - besonders bei hohen Temperaturen - ist sehr hoch.  Ich habe nicht mehr genau im Kopf, wie viel km es waren, mehr als 4000 waren es definitiv nicht.
Idealer Reifen, wenn du mal eine Regenperiode im Sommer hast oder aber im nasskalten Winter.
Zusatz: Sehr tolles Projekt. Sauber gearbeitet mit viel Liebe zum Detail und stimmiges Gesamtbild.
Bearbeitet von Schaltfreund
vor 13 Stunden schrieb sinfonique:
vor 13 Stunden schrieb px211:
Kann ich ebenfalls bestätigen. Habe die Dinger leider auch auf der Alltags-PX und eiere bei Regen (zum Glück selten in Hamburg :-D) auch senkrecht durch Kurven. Ganz gemein sind Teerflicken und Straßenmarkierungen. Die Brems"leistung" wird auch deutlich schlechter.
Da ist der uralte S1 Ersatzreifen mit DOT vor 2000 mindestens so gut.
Ich hab mit meinem Conti Twist in 3.50-10 auf meiner Alltags-O-PX200 auch bei Nässe keine Probleme:withstupid:
Gut, fahre den nur hinten (vorne ein älteren Conti Zippy 1) aber kann da jetzt erst mal nichts schlechtes Berichten.
Al.
vor 24 Minuten schrieb anfahrer:
Hinten ist der Twist ja auch ok, aba vorne rutscht der auch bei nur glatter Fahrbahn ohne feucht weg.:whistling:
nicht als 130er... da is es hinten wie vorne ein eiertanz
vor 3 Stunden schrieb AAAB507:
Also quasi IMMER :-P
Grüße aus HH!
vor 27 Minuten schrieb chrisan:
:whistling:
Vorne geht bei mir eigentlich sogar - mir geht der vor allem hinten weg. Zum Glück - vorne fände ich noch schlimmer.
Nun ja, ein anderer Kopf, eine kleine weitere Änderung und ich lege trotz Laufleistung etwas nach :whistling:.... aber die 3 vorne mag noch nicht fallen... außer ich bedüse noch einen Ticken magerer...
6B94F623-C91B-4D23-9A9C-3FD9867EF265.thumb.jpeg.21fe1e8016178e880d0766ef2147024e.jpeg3B812F24-8108-4D50-8013-16CBFD8758BD.thumb.jpeg.f56179654b5e07a556cdfb237e4dc771.jpegBC35E3AA-C020-4325-96C3-165A938F4B93.thumb.jpeg.395d33d556985d684e38ebc2737411c0.jpeg
  • 3 Monate später...
