SOUNDS FROM THE SHELTER VOL. 32 - THE RIMINI SPIRIT
Neuer Podcast jetzt online - stream or download. Freue mich über jederlei Feedback!
Sounds from the Shelter
A bunker full of music
Rimini Rare Soul Weekender 2016 #13 - A weekend of sea, sun and soul!
Had such a great time there and heard some fantastic records.
Back home I knew I just had to dedicate my next podcast to that weekender. So down the stairs into my shelter I went and pulled out a selection of tunes that either got played over the weekend or would have fit in quite nicely.
Luther Vandross . Are you using me . EMI UK 12 *
Jamie Lewis ft. Chance . Street life . Purple Music 12 *
Philly Cream . Motown Review (12") . Fantasy WMOT 12"
James "Bootie" Tuten . This is a love affair . Ultimate 45
William Bostic . That's what you do to me . SOR 45
Blacksmoke . Sunshine, Roses and Rainbow (D) . German Casablanca LP
John Edwards . How can I go on without you . UK Kent Promo LP
Garfield Fleming . Don't send me away (12") . D.Trax 12"
The Whatnauts . Help is on the way (12") . Harlem Int. 12"
Carol Anderson . I found love . Coup LP
Randy Brown . I'm always in the mood . Parachute LP
Starvue . Put the BS aside . Midwest LP
Numonics . You lied . Hodisk 45
Tommie Young . Hit and run lover . Soul Power LP
Bobby Sheen . Something new to do . Jamaican WB 45
Tommy Tate . I can't do enough for you baby . Record Shack 45 TP
LaVern Baker . I'm the one to do it . Brunswick LP
The Ohio Players . Love slips through my fingers . Trip LP
Freddy Butler . That's when I need you . US Kapp LP
The Ovations feat. Louis Williams . I'm in love . MGM 45
Lillian Dupree . (I've got a) Shield around my heart . D-Town 45
Jon Lucien . Would you believe in me . RCA LP
Karin Jones . Ready, ready love . Handshake LP
Vaneese & Carolyn . Goodbye song . UK Expansion compilation
(I played both at the very first weekender in 2001)
Bearbeitet von benji
  • 8 Monate später...
    • Das Stichwort heißt: "Wiederherstellungskosten". Angenommen, du gehst zu ner Werkstatt und sagst denen, du möchtest ne PX haben, neu lackiert, über 20 PS Leistung, Scheibenbremse, bisschen Fahrwerk, alles eingetragen und fix & fertig abgestimmt, ohne selbst einen Handschlag dran zu machen. Dann kann es schon sein, dass da ein Betrag rumkommt, der ins 5stellige geht. Das zahlt natürlich keiner. Aber das wäre halt die Summe, die es kostet, so etwas aufbauen zu lassen.
    • Na ja... würds ei fach messen Block mit dichtung trocken zusammen. Dann spalt KuWe Wange zu Gehäuse messen. Zerlegen Lagertiefstand im Gehäuse ermitteln.   Wenn der Spalt 0.8mm ist und das Lager 0.5 tief dann würde uch 1.3mm abstand Ring zu Wange machen
    • Es sieht so aus, als hätte ich für 60CHF inkl. Versand einem aus der Schweiz ergattern konnte... Ich lass das hier mal offen bis ich weiß, dass er auch funktioniert. Danke schon mal für alle Hinweise
    • Hallo,   hat jemand zufällig vielleicht einen Schaltplan von einer motovespa 125 cl ? Hab folgendes, Motor aus einer 125er cl . Top Zustand aber mit femsa Zündung und keine Aufnahme für Ducati Zündung. Jetzt gehen aus der Zündung aber nur 5 Kabel raus. 2x braun,1x schwarz die gehören zur Zündung. Und dann nur noch grün und gelb. Hab ne 12V Konversation Kabelbaum drin. Weiß jemand wie ich das ganze anschließen soll? Ist ja 1 Kabel zu wenig. Die GT usw haben ja insgesamt 6 Kabel. Meine hat aber nur 5 und das sicher original... vielen Dank schonmal
    • Ich kann die Zylinderhaube/Motor immer anfassen ohne mir die Hand zu verbrennen.   Da lief mein M200 wesentlich heisser!
