I've fitted a Polini208 on my PX200GS With elestart...
I've removed some material on the sylinder, as the flywheel rubs on it...
But I haven't removed enough, as it still rubs a little.
-how much can I remove without going through the cylinder?
I Guess the Polini208 should work With elestart flywheel?
Rgrds
Øyvind
Bearbeitet von Svint1
Hi Tobi,
He he, the elestart is not needed
-but highly preferred...
Was jus wondering if there is a risk of going through to the ports if I use the Dremel to remove a mm or two...?
Sent from my iPhone using Tapatalk
Think about to Do it the other way around.
Remove the starter rim from the flywheel and machine the seat for the starter rim at the flywheel  on  a lathe 1 to 1.5 mm deeper.
That will solve your problem.
  Am 21.2.2017 um 22:52 schrieb wheelspin:
Aufklappen
Sounds like a good sollution, except that I don't have a lathe...
That's why I'm going for the Dremel sollution.
-just a bit afraid of taking too much and going through the metal...
  Am 22.2.2017 um 08:50 schrieb Svint1:
Aufklappen
take a look at timey's stuff though.
his " Doppelzirkelbausatz " will help to go not to crazy with the dremel. Take a look ->
