I'm currently building a M244-engine for my SS180.
I'm using a Pinasco VXR26/26 carb With the funnel and was wondering what airfilter to use.
As it is to be fit in a SS180 frame, I'm not using a hose Connected to the frame.
Any suggestions what airfilter to put on the carburettor Box?
Rgrds
Øyvind
To use the original hose w/o an additional air filter is the smartest way to solve this issue. That is what I think.
I'm not sure but I guess you'll need an adaptor to connect the SS hose to the p-range carb bowl or you do it the redneck way- just tie it down to the needed diameter. To use one of the original SS metal ties could be an optical "plus"...
OK, I'm leaning more towards a setup similar to the Polini venturi kit, but just buy a filter, as the Pinasco comes with a funnel...
Sent from my iPhone using Tapatalk
Of course you can solve it like this.
But this will offer you the roaring and pesky sound of an open rotary valve engine. And the fact that a displacment Monster like the m244 is will make it worse when it takes it's breath.
If you have two Bad ears or you just don't care- Go for it.
But this is not the Sound that I would like to have with this little cutie.
Just my two Cents
Hmm, the noise/sound from the engine is ok for a while, but not for long distance riding...
Sounds like the hose is going back on...
Thanks for advice! [emoji1303]
    • Moin, mich ärgert an meiner PK50 XL schon seit längerer Zeit meine Lenkerabdeckung. Der Vorbesitzer hat mir noch eine zusätzliche mitgegeben, diese ist aber von einer PK 50s, durch 2 Kontrollleuchten gekennzeichnet. Die originale will aber nicht vernünftig passen. Würde nachher sonst noch ein paar Bilder anhängen. Ist das Problem bekannt oder ist das ein Einzelfall?
    • Ohne Dämpfung schlägt das Instrument ohne Verzögerung auf die Sollposition an der DC-Quelle. Leichtes Klopfen lässt die Nadel tanzen. Mit Dämpfung, egal ob das intakte Original oder das jetzt reparierte mit dem zähen Silikonöl, passiert beim Klopfen gegen das Instrument gar nichts.   Ich schaue mir das noch eine Woche an. Wenn es dann noch immer geht, wäre das eine funktionierende Reparaturmaßnahme.   Wer mag, kann mir eine PM schicken, würde 1ml oder 2ml Öl in eine Spritze packen und für 4€ per Maxibrief verschicken. Reicht für mindestens 20 Instrumente.
    • Wir sind in den letzten 3 Jahren in der "Familien PK50S" auch einen Polini 50, 16/16 und Sito+ und 4Gang gefahren. Alles p&p nix gefräst. Der leiseste ist er nicht. Verbaut war original Primär mit einem 16Z Ritzel von Olympia, also 4,31. Es sind und bleiben 50ccm, mit längerer Primär hätte ich in nicht fahren wollen. Die "Mehrleistung" macht der Polini in dem Setup nur durch Drehzahl. Ich bin gespannt ob Du mit der 4.0 erstmal glücklich wirst.
    • Hallo zusammen,  Will mich um ein paar Altlasten reduzieren. Gibt es eine Nachfrage für Rahmenschutzbügel? Hab auch noch einen Motor mit DR 75 F10, sieht  etwas gerieben aus, fuhr damals unauffällig, Bananenauspuff und Kleinteile.  Ist Motorverkauf im Ganzen oder in Teilen sinnvoll? Was erster Prais?
