Hi folks.
I bought Pinasco flytech and I would like to connect it directly WITHOUT battery. But scheme from Pinasco is minimized and electric is not my strong side. Can you help me? Did anybody install Flytech or Vespatronic w/o battery?
Danke, David
  • thisnotes4u änderte den Titel in Vespa GS VS5 und Pinasco Flytech - OHNE Batterie
What about this scheme? kill the engine by 4-1 with orig. switch? Pin 7 free - the cables moved from 7 to pin 6. Lights/horn only from yellow. Engine run only in switch position 3 (pins 4-7 and 2-5-6-8).
59b26bc3cc62f_VespaGS_VS5-UPRAVAFT-final2.thumb.jpg.1fb7c84066e5b82ea0d59476b5e30a58.jpg
Bearbeitet von bezchvostka
Hi Housefrau :)
I try to kill engine via pins 4-1 (picture above). Everything is working well, only when I use horn switch - all lights goes off.
For me, It doesn´t matter..but If you have any scheme of your flytech..thanks
