hello all,
sorry for the english!!!
i have a malossi 210 mhr
mikuni tmx 35mm
60mm bell crank
vforce reed mrp reed block
1600g flywheel
sip jl right hand exhaust
I'm looking for some carburettor settings for the tmx 35mm
thanks in advance !!!!! shane australia
Hab folgendes Setup verbaut:
Vespa PX 200 .. Malossi ALT (196AS 138ÜS) .. 60er Lippenwelle .. 1,5 Fußdichtung .. QK 1,25 .. Mikuni 35TM (265 HD 27,5 ND) .. MMW Membran V-Force .. Racing Resi Eigenbau-Auspuff ..Orginal Zündung 18,5°.... HP4
hi thanks for the reply!
what needle are you using???
many setups with malossi 210 -zylinders won´t work with the original 53 needle at low upm. 57ér ist often the right choice with a tuning exhaust. do you drive with airfilter ?
yes i drive with a airfilter
I've got it set up
300 main
58 needle
20 pilot
but it feels lean
Am 9.10.2017 um 06:16 schrieb ssteam177:
I've got it set up
300 main
58 needle
20 pilot
but it feels lean
Hey, try the 56 or 57 needle starting with needle clip in middle position, and also pilot jets 20-30.
Main sounds not so bad.
thankyou
  • 1 Jahr später...
