Hi,
My name is Gio, and i've been on the forum for a while, but i don't post much because of time (sorry for that)
I've worked on a number of Lambretta's (or engines) but never had this problem and it's driving me mad!
The Lambretta in question is an 1966 Italian 150 Silver Special. I've rebuild the engine but kept as much original parts as possible (also original paint etc).
The ignition is the original 6 pole Ducati, 6V, no battery!
I've been having a problem with the lights that work with the ignition switch in position 2, so the speedo bulb and bullet type lamp (position light?) and rear light.
The Lambretta starts without a problem, first kick every time with the key in position 1 or 3 (headlights etc)
but as soon as i put the key in position 2 it cuts out.
I've checked everything and even changed the complete wiring
loom, the ignition switch and the light switch, just in case... al ground cables and lamps are also new.
The problem seems to be the purple wire coming from the ignition!
If i put the brown cable in the place the purple needs to fit the speedo bulb and bullet lamp work!
If i put the purple cable in the position the brown has to be, the bike cuts of with the ignition switch in position 3!!
So, before you say change the stator....i already tried with a second one i had!!!
This is the weirdest problem i ever had.
Is there someone that had the same problem? Or does the Ducati 6pole stator have a known issue with the purple wire?
I've checked everything else a million times and tried everything i know...always same problem!
If i forgot something, please ask.
I hope someone can help me.
Sorry for writing in english... i understand german, but cannot speak or write it very good!
..there are (maybe slightly corroded) other items left:
-black round junction box
-cev light bulb holder / headlight junction
>check these
Thank you.
junction box is new, even changed it twice and checked all connections.
bulb holder where cleaner all connections and even changed place for purper wires.
yesterday i even changed the coil with the purple  wire for a third one, and another flywheel. Made an extra ground for the speedobulb and changed the two small lamps again...no luck.
I suppose it's something shorting out, but i've double checked grounds.
All switches are new by the way.
Today i've noticed that if i rev the engine when i put the switch in position 2 the bulbs light up for a second before the engine cuts off.
At idle the engine cuts off immediately.
In position 3 with all lights on and pushing horn or brakelights there are no problems at all at idle...
Thank you for thinking with me, all tips are always welcome with this weird problem.
I've changed the flywheel for a third time, also cleaned all grounds and checked sparkplug gap once again and now all is working. I think both flywheels i used had same problem (to little magnetisme?)
But now i have some kind of knock/trembling sound coming out of top end. I hope its the flywheel thats slightly out of balance and notthing else broke ;).
At least i now know how to fix the purple wire problem.
Thanx to all for your help.
this topic can be closed
Grtz,
Gio
    • Naja, ich habe ein Canyon Grail AL und mal auf die Endurace Klasse Endurace CF 7 oder eher sport Ultimate CF SL 7 geschielt. Hauptunterschiede sind Oberrohrlänge und Radstand wie beschrieben.
    • Habe schon einige Metall Siris eingebaut und jetzt zum ersten mal das Problem, dass der, wenn bündig eingebaut, am Lager angeht. Gleiche Situation mit Corteco blau und braun. Verbaut war ein brauner Rolf.   Ich hatte noch einen schwarzen Rolf, den habe ich etwas abgeschliffen und bündig eingebaut, jetzt schleift nichts mehr am Lager.   Lässt sich dies auf das Baujahr eingrenzen? Ist eine 92er Lusso. Wahrscheinlich war der originale Siri auch nicht bündig eingebaut. Gibt es da Tollerranzen mit den Gehäusen?       Optisch schaut der braune Corteco am flachsten aus, vermessen mit dem Messschieber, ergibt sich kaum ein Unterschied. Beim Rolf ist mir aufgefallen, dass die Gummilippe nicht über das Blech übersteht, bei Corteco ein wenig.     Der Rolf scheint am flachsten zu sein, habe ihn trotzdem etwas angeschliffen, damit ich nicht noch einen Siri verschieße.
    • Also ich habe jetzt nochmals entlüftet, weil ich sich die Bremspumpe noch etwas weich angefühlt hatte. Es kamen noch kleine Luftblasen raus. Nun ist es besser, aber ich habe eine sehr schlechte Bremswirkung. Hatte zuvor neue Malossi rot Beläge reingemacht. Kann es sein das die sich noch einschleifen müssen? Fühlt sich so an, als ob die Scheibe fettig wäre. Ist sie natürlich nicht. Da ist die Bremstrommel hinten viel bissiger.
    • Danke, aber dann bin ich raus. Hatte da so eine Vermutung, passt aber nicht...  Aber sehr schick
