hello
I´m rebuildind my engine with pinasco crank competition 62mm stroke and malossi mhr221 and pinasco 26/26r and exhaust rz mark II
after measure the inlet , i have open 135º before TDC and close 75º after tdc. 210 degrees in total open.
my question is: sould i close the valve litle bit? or should do nothing?
should i weld aluminium ou use epoxy? is safe?
best regards
eduardo
Please also check the flywheel cone!
https://www.germanscooterforum.de/topic/321110-pinasco-62mm-competizione/?do=findComment&comment=1068724558
The cone of my crankshaft was too long, so that the flywheel could not be fixed properly without using a custom-made washer (see picture in the link above).
Greetings,
Arne
Bearbeitet von alfonso
link
On 2/10/2019 at 8:51 AM, alfonso said:
Leave it as it is.
The timing is ok.
hi
so long intake don`t be malefic for low rpm power?
REGARDS
vor 11 Minuten schrieb edumegacc:
hi
REGARDS
Maybe a bit too much fuel consumption, but I am quite sure you will not lose power because of the intake timing.
Beside that, a MHR is not built for low revs anyway.
With your components, I‘d rather go for a Malossi Sport or Polini.
