Hi all,
First, please excuse that I’m posting this in English, I hope it’s ok (However, I do read German). Thing is that I have converted my Quattrini M1 60 to case reed using a Parmakit reed manifold (the one with a CR80/older, small Quattrini M1L reed). I've turned it around so the carb is pointing out through frame since the frame was already cut. My question is if anyone knows of a short, totally straight carb rubber flange that fits, or could be modified to fit the Parmakit manifold/reed cage? Does anyone for example know of a straight RD350 inlet rubber flange? As for now I’ve just shortened the inlet pipe as much as possible and I’m using the short MB connection rubber, but it would save a few millimetres to use a rubber flange instead of the metal flange plus connection rubber. Any hints or suggestions are very welcome!
Usually the oem motocross manifolds are strait rubber flanges. Did you try to look for a CR80 flange on google/ebay?
Thanks! Yeah, I've looked but have only found angled ones.
vor 18 Minuten schrieb Brosi:
You could also build your own by combining a flange plate with a universal rubber flange. You only need to drill and thread the holes for the ruber flange into the flange plate.
Or even better Use the original Quattrini flange. Cut the pipe part, level the surface with a file, drill and thread the holes and attach the universal rubber flange.
Thus you can even keep the original Quattrini flanges stuffer.
Bearbeitet von Brosi
vor einer Stunde schrieb Brosi:
Thank you Brosi, really good ideas!
Danke. Wollte eigentlich nur das Bild vom originalen (alten CR80) verlinken, weil ich dachte, den hätte er sowieso. Hat wohl nicht ganz geklappt.
    • Ich gehe davon aus das Ja, das Problem ist ja nicht die Steuer an sich, sondern das es 2 Bodenrichtwerte für das Grundstück gibt, einmal 3/qm vom Gutachterausschuss der Stadt Kiel um den Verkehrswert zu bestimmen und einmal 300/qm von den selben Gutachtern um die Grundsteuer zu bestimmen. Spannend wird es das der Bund 1000qm von mir braucht um eine Autobahn zu bauen, bekomme ich jetzt 300.000 dann zahle ich lächend die nächsten Jahre die erhöhte Steuer, ich vermute aber die legen die 3 an, was dann glaube ich doch mal ein Gericht klären sollte. Zusätzlich delikat ist die Geschichte das wir sowieso schon im Rechtsstreit mit der Stadt liegen um den Wert des Nachbargrundstücks.
    • Bin am 21.12. die letzte kleine Runde gefahren, hatte Urlaub zwischen den Jahren und dann kam selbst im Rheinland so komisches weißes Zeug vom Himmel... meine Spikereifen passen leider nur aufs Cross Rad. Jetzt ist fast alles getaut, morgen trau ich mich noch nicht (der Weg zum Dienst ist hauptsächlich Nebenstraße und Feldwege, da wird nix gestreut Sonntags um 6) aber nächste Woche sollte es wieder klappen.   Ich fahre ein Trek Domane+ AL5, schon das zweite. Das erste hatte ich 2023 im Sommer bei XXXXL gekauft (alle kleinen Händler im Umkreis haben mich ausgelacht als ich im August ein Rad kaufen wollte... O-Ton "Kommen Sie 2025 noch mal wieder...") und nach diversen Problemen, unter anderem 6 gebrochenen Speichen nach einander, zurück gegeben. Bei einem anderen Händler das neuere Modelljahr vom gleichen Rad etwa 1000€ günstiger ergattert und voll zufrieden. Keine einzige Speiche bis jetzt gebrochen. War wohl ein Montagsrad.
    • Vespa gekauft und steht bei mir in der Garage. Habe sie mit dem Anhänger geholt und sie steht super da :).
