Hello,
Someone have a SIP hydraulic clutch available?
I'm looking for one, but if I cant find I would like to build one. My only issue is to find or build a hydraulic plumber, as SIP make to weld on original cover plate.
Please could you help me on this.
Regards
João
Hello, as the rear disc brake. Not needed but Is a good feature.
I build one, despite is a cool thing, i dont see any difference.
Is just to feel the difference between the two techniques.
So I would like if, someone have this experience.
Several years ago I mounted the first Sip Version on my PX. I think because of the same reasons like you have...just to play around:-D.
The Sip parts are normal turn parts: a piston made of steel an the fitted hole including two Orings. Thats it! But if you really want a functional clutch I would prever the combined version: just hydraulic till the pump so you can use an ordanary clutch cover.
For example:
https://www.amazon.de/dp/B01MAXMNOH/ref=cm_sw_r_other_apa_i_6.eqEbJ8568E8
Bearbeitet von lokalpatriot
