THE PIONEERS auf SUMMER SAFARI 2004
Summer Safari in Leipzig / Werk II (Kochstr.132)
27.08.04
28.08.04
Acts (Bands):
THE PIONEERS (Ska & Rocksteady / JAM)
THE FRANK POPP ENSEMBLE (supercharged 60s grooves / D)
DIE SPUTNIKS (Surf, Twang & Big Beat / GDR)
LOS BANDITOS (instro trash-o-rama / D)
THE PEACOCKS (High-Speed-Rock'n'Roll / CH)
BOOGALOO INVESTIGATORS (Dynamite 60s R'n'B / UK)
STUDIO 9 (Rocksteady & Ska/ D)
THE SCHOGETTES (All-Girl-60s-Pop / D)
WESTERN SPECIAL (traditional Ska / F)
MIKROWELLE (Elektro-Surf / D)
THE CHEEKS (Power Pop / D)
HILLBILLY MOON EXPLOSION (Girl-Powered-Rockabilly / CH)
COOL JERKS (60s Beat / D)
SPO DEE O DEE (Rockabilly / D)
JANCEE PORNICK CASINO (Surf / US, GUS, D)
Acts (DJs):
Sideburn & Switchblades (Berlin)
King Kranz (Berlin)
Katja Metzner (Berlin)
Leo Ernst (Muenchen)
Joerg Brenner (Muenchen)
Copasetic Disco Team (Aachen)
Peanut Vendor (Leipzig)
Howie Paris (Dessau)
u.v.a.
Special: THE MEXICAN WRESTLING SHOW
Erwartete Besucher:
ca. 1500
www.summer-safari.de
so hiernochmal...
DAS KOMPLETTES LINE UP/ Freitag, 27.8.:
Bands: (Outdoor & Indoor)
THE PIONEERS (Ska & Rocksteady/ JAM)
LOS BANDITOS (instro trash-o-rama/ D)
THE PEACOCKS (High-Speed-Rock?n?Roll/ CH)
HILLBILLY MOON EXPLOSION (Girl-Powered-Rockabilly/ CH)
COOL JERKS (60s Beat/ D)
MIKROWELLE (Elektro-Surf/ D)
JANCEE PORNICK CASINO (Surf/ US, GUS, D)
DJs: (4 Areas - Outdoor, Hipshakin? Groove Club, Waitiki Lounge, Jamaican Lounge)
King Kranz (Monogam, Berlin)
Killer Mambo (The Vampires, Berlin)
Snorre (Werk II, Leipzig)
Katja Metzner (Roter Salon, Berlin)
Franz Heidl (Hip City Soul Club, Berlin)
Max Schmidt (Berlin)
Martin ?Danger? Rank (Club Separeé, Berlin)
Howie Paris (Beatclub Dessau)
Dr. No Soulsurgery, Leipzig)
DAS KOMPLETTES LINE UP/ Samstag, 28.8.:
THE FRANK POPP ENSEMBLE (supercharged 60s grooves/ D)
DIE SPUTNIKS (Surf, Twang & Big Beat/ GDR)
THE BOOGALOO INVESTIGATORS (Dynamite 60s R?n?B/ UK)
THE SCHOGETTES (All-Girl-60s-Pop/ D)
WESTERN SPECIAL (traditional Ska/ F)
THE CHEEKS (Power Pop/ D)
SPO DEE O DEE (Rockabilly/ D)
Peter Brandenburg (Leipzig)
Peanut Vendor (Soul-Magic.de, Leipzig)
Leo Ernst (Atomic Café, Deeper Shade Of Blue, München)
Wolfgang Dirrigl (Atomic Café, Deeper Shade Of Blue, München)
Jörg ?Puresoulie? Brenner
    • Ich wollte nochmal eine Rückmeldung geben. Die schöne Special war wie zu erwarten eine mittlere Baustelle. Da kam dann eins zum anderen:  1. Lenkerkopf falsch montiert - siehe oben  2. Eine Felge hatte einen Riss, die andere Langlöcher. Alle Radschrauben sahen aus, als wären es 100x wiederverwendete originale. Beide Reifen waren übrigens mind. 25 Jahre alt (DOT 2000 bzw ohne Angabe), hatten aber noch fast neuwertiges Profil.  3. Die hintere Bremstrommel war für 11-Grad-Konus, verbaut war ein 8-Grad-Konus, das hat böse gewackelt. Dass der Inbus der Sicherungsschraube tot war, ist sicher keine Überraschung. Alles neu.  4. Die Kupplung rutschte - Beläge waren verglast/verklebt. Wer weiß, was da als Getriebeöl verwendet wurde, hat jedenfalls komisch gerochen. 5. Die Kette hatte > 3 cm Spiel. Zum Glück war noch genug Luft beim Kettenspanner. Die Ritzel sehen noch gut aus.  6. Die Züge waren im Lenker falsch verlegt mit zu engen Radien. Alles neu und schon schaltet und kuppelt es sich einwandfrei.  7. Die originalen Alu Zierteile ohne Nupsis habe ich mit Karosserieklebeband befestigt, na ja, zumindest hält es.  8. Der Auspuff war völlig verkokt, jetzt ist ein alter Ancillotti by Sito verbaut, der klingt und fährt sich okay.  9. Der Benzinhahn hat nur in einem kleinen Bereich zwischen normal und Reserve etwas durchgelassen, also neu.  10. Vergaser komplett neu abgedichtet (Nadel war völlig hart, gestaucht und natürlich undicht). Da ist eine 107er HD und ein Mischrohr Typ 4 verbaut - keine originale Kombi, aber mit dem Sportauspuff passt das ganz gut.    So fährt sich das überraschend gut, Topspeed dürfte bei um die 80 liegen. Der erste Gang ist ungewohnt lang, aber dafür sind die Abstufungen schön eng, so dass man gut in die Gänge kommt trotz der Minderleistung.  Hier noch ein Foto und ein Dankeschön ans Forum.
    • Ich möchte nochmal Rückmeldung geben, die Kiste läuft jetzt bin knappe 50km Probe gefahren ohne Probleme. Einzig der Schieber vom PHBH klemmt abundzu im unteren Bereich. Ich habe die einen 2. PHBH der hatte eine längere Feder verbaut aber das hats leider auch nicht gebracht. Gibts da noch einen anderen Trick?
    • … arbeitet als Abschmecker im Klärwerk.
    • nönö, das passt schon so!!
