Hello
Anyone is running an imola engine with a PHBH 30 ?
I can't manage to set it up, my best result is
main 145
AV266
X3 first clip from top
The result : acceleration is OK unitil I reach 1/2 - 3/4, there it runs crap.
And the plug is grey.
I tried a 150 & 140, but it's worst
Li 125 engine, imola kit, high compression head, imola reeds, gianelli exhaust MK2.
If you don't run on a PHBH but another carb, can you tell me you specs, and what manifold are you using ?
The Oko PWK is too small for the imola rubber manifold.
Thanks for any help.
Zylinder Imola 185ccm
Vergaser Mikuni TMX 30
Bedüsung HD290, PJ52,5, ND22,5, Nadel 2ter Clip v. oben
Mischrohr N-9 (Serie 622), Nadel 5EL68-3, Gasschieber 4,0
Auspuff PM
Übersetzung 18/47 (82er Kette)
Getriebe LI 125 (spanisch)
original TS1 manifold
Timm
Hello
main 145
AV266
try the second or even the third clip from top
Jetting Specifcations PHBH 30mm
Imola 185 standard
Air screw 1 - 2 Turns
Pilot 60
Atomiser AS266
Needle X2
Needle position 2nd clip
Main jet 118
setup for clubman exhaust
Hello
I went down to a 140 main,
X2 needle : second clip from top
1-1/2 air screw
Engine start fine, revs ok on the road until I reach a certain rpm (after 3/4) and if I manage to go over this stage it goes well. But the only way to do this is to be down hill. Up hill it's very hard to go behind this point.
Any idea ?
The plug is very light brown.
..in my opinion the x2 isn't the right way to solve your problem...the plug shouldn't be grey or light brown
try the x3 on the lower clips (2nd, 3rd or 4th from top) and the 140 Mainjet
