Looking or help with two engine builds. Working on building a Small frame and Large frame engine for top speed only in a straight line. The top speed should be reached within 3 miles. So i am trying to find the Tallest gearing possible and if the chosen kits will have enough Torque to pull the gearing
- Smallframe will have the Quatrini m200 cases and cylinder. Does any one have any Dyno info or where I could find more info? Also best exhaust for torque? And lastly does anyone know of a higher Primary gear than the 29t crimza?
I know these types of projects are costly but I want to also be as reasonable as possible price wise.
Thanks to anyone who can help point me in the right direction!
There you can find everything about the Quattrini M200:
https://www.germanscooterforum.de/topic/363166-quattrini-200-cc-smallframe/?page=432&tab=comments#comment-1069243518
I think for top-speed, you should not look for best torque. You should look for best power with a wide powerband.
Longest primary I know ist the DRT "PRIMARIA DRT/TOB z56-26 (2.15)":
http://www.drtdenis.com/catalogo/sottocat.htm DBE?idcat=215&catee=01
At which events do you want to ride it?
Bearbeitet von jolle
Thank you for the links!
In september the scooter hopefully will be at Bonneville salt flats ;)
20 hours ago, gertax said:
How fast du you want to go? And where can one do 3 mile top speed runs? :-)
As fast as possible. A real life run of over 100mph would be amazing.
You can do 3mile runs at the Bonneville Salt flats ;)
vor 14 Minuten hat cvjosh folgendes von sich gegeben:
That should be a feasible task.
You should aim for about 45 rwhp (or more) at sea level, I'd guess. And depending on the rev range and gearing (the total final gear ratio is important, not so much die primary reduction), this can be achieved without a super long primary reduction, too. I've done it with a 2,65 ratio, for example (not an M200 engine).
Hopefully, one day I'll be riding at the bonneville salt flats, too!
Thanks for the insight!
what did you hit 100mph with if you don't mind me asking?
Just a calculation example:
primary ratio = 2,15
ratio 4th gear = 2,3-2,4
3.50-10" wheel circumference = 1,3m
max rpm. ~10500rpm
--> 99-104 mph
PS: For 100mph you don't need 45hp and more. Would be helpful, but isnt' needed.
There are several racing teams which hit the 95-100mph in Magny-Cours (France) with about 35hp and M200 engine. :cheers:
Bearbeitet von FalkR
Gerade eben hat cvjosh folgendes von sich gegeben:
You're welcome! If you have not done it already, it will be probably useful to make an excel sheet with all the gearing and tire options.
There are several of my scooters with different setups capable of 100 mph. Although, I had to hurry, as most of the time I had only a quarter of a mile to accelerate.
Some pictures and further technical information can be found in my advent calendar
vor 7 Minuten hat FalkR folgendes von sich gegeben:
You are right, 35 does the trick. But keep in mind that Bonneville is at an elevation of ~1300m, so I would target 45 in order to have ~38 available at the salt anytime (and 3hp as a backup, as being stuck at 99,7mph would suck).
Yea this is what I have stuck in my mind. I know bikes will go over 100mph on a drag strip or on perfect tarmac. The rolling resistance of the salt is something myself and my buddy which i am working on the project with are heavily keeping in mind.
Also paring the cylinder with the correct pipe to keep the Power band as wide as possible as to not have loss of speed if we fall out of it in too short of time.
vor einer Stunde hat FalkR folgendes von sich gegeben:
.... aaand: Those engines are NOT built for top speed!
They are built for fast turns on short racetracks.
You are losing power because of the reduced air density.
BUT: You lose drag through the reduced air density as well.
I made a rough calculation a while ago for a certain engine and scooter. On paper it had the same maximum speed like in sea level conditions.
But the biggest uncertainty is the salt, Josh, do you have any reliable sources regarding slip and friction?
My goal would be to reach as much HP as possible. With a broad powerband and overrev capability
3 hours ago, gertax said:
Seems like something in between 2 and 5 HP for rolling resistance @ 100 mph on salt can be estimated
https://www.hayabusa.org/forum/threads/formula-for-calculating-rolling-resistance.8937/
Thank you for the LINK! I was looking for some fixed details about the calculations needed for the salt.
Now I am thinking that trying to achieve 45-50hp would put us in a safe place regardless of the salt conditions.
moving on from this though I will have to work out the gearing and figure out which clutch will hold the 50hp with out exploding.
Maybe interesting for your project:
M200 - exhaustport 195deg, transferports 127deg
Stock Quattrini crankshaft 56.5mm stroke
35mm PWK Airstriker Carburetor
Vespatronic ignition
M200-Race exhaust
The dip @6000rpm was the wrong carb needle Setting.
vor 11 Stunden hat cvjosh folgendes von sich gegeben:
In case you would like to take the shortcut, engine wise, an @egig 250 engine would be just perfect for your demands. They are ready to run and come with about 50 rwhp and all components strong enough to keep everything together. And there is potential for more hp (Erich managed to reach 70), whereas on the M200 I do not recall having seen anything above mid 50ies, hp wise.
M200-Race exhaust
@FalkR thank you for sharing the  info! It is extremely helpful :)
 @alfonso  @gertax - EGIG makes some amazing stuff from what I have seen, though i know his products are worth every cent they are just to much for our budget. Also the fun is seeing if we build the motors to do what we want.
    • Ja sicher! Extrembeispiel: jemand hat ein kleines Feldschlösschen auf dem Land mit 10 Hektar Grundstück und hat bisher 400 € im Jahr Grundsteuer bezahlt. Soll nun 1600 € im Jahr bezahlen. Vorher subjektiv zu wenig. Gegenbeispiel: Eigentumswohnung in der Stadt im 20-Parteien-Haus mit 60 qm Wohnfläche geht von 500 auf 300 € runter. Reine Phantasiezahlen. Was ich tatsächlich ziemlich daneben finde, ist die Tatsache, dass wir im gleichen Land leben aber unterschiedliche Berechnungsgrundlagen für die Grundsteuer haben. Finde ich ein Unding. Als BaWüler finde ich unsere Grundlage in der Tat relativ fair und nachvollziehbar.
    • Naja generell ist es ja eigentlich richtig und auch nett von ihm das er alle bedenken will. Amerika ist doch der Kontinent, da gehören also alle von Canada bis Chile dazu. Oder sehe ich da was falsch?    Klar aber wer Mexico und New Mexico nicht auseinanderhalten kann tut sich auch mit Amerika und United States of America schwer.
    • Im Playstore kann man die App bewerten.
    • Denke ich nicht, weil der Sprintkotflügel auf der PX Gabel verbreitert werden muss. Habe schon paar angepasst und hier sieht es nicht so aus.   Dazu steht der Roller einigermaßen Waagerecht und nicht tief genug für Superlow. Der Schwingenwinkel auch eher "Standard"   Wieder Glaskugel, aber für mich deutet da überhaupt nix auf PX Gabel hin.   Sprint72. Woher kommst du denn?  Wäre am besten da schaut mal jemand aus dem Forum 10min drauf.
    • ich würde mal was zwischen 2500 und 3000 in den ring werfen wobei ich die 3000 eher langfristig sehe. unter 2500 dürfte denke recht zügig jemand den kofferraum aufmachen.   blech basis gut, basis motor ggf nutzbar oder zumindest verkaufbar und der richtige der auf so eine farbe steht muss nichtmal kern sanieren.  ist allerdings eine spezielle farbe die eher die atzen unter uns (wie ich) geil finden. für den neureichen vespisti definitiv zu wenig beige und braun an der karre   problem: die atzen wie ich, wollen nix bezahlen die neureichen vespisti schon aber s.O. daher meine schätzung eher etwas verhaltener.
