Hello, (I can read German, but writing German is a bit hard, hope it won't be a problem)
I have a Vespa V50 crankcase (around '71 I guess) and want to install a vespa V50s gearbox in it. Only the Nebenwelle won't fit, is this correct? And can I change the crankcase that it will fit or is this not a good idea?
Thanks in advance,
Teus
Bearbeitet von goon326
yes, there are 2 different cases at this position - one is wider for the longer gear transmission ratio.
what you are going to use is the longer one, are you sure this makes sense?
i suggest to take the standard pk transmission (the whole, not only "nebenwelle"!)
that usually fits also better to all kind of engines we use.
standard case (the one from your pic where the "nebenwelle" is not fitting):
right case for the "nebenwelle" you show in the picture:
also a big disadvantage is, that you can not spindle that case to 54mm of stroke in future.
if you do so, this would need some welding before, otherwise you end up like this:
Bearbeitet von Motorhead
Thanks for your elaborated answer! I also have the PK transmission (4 gears) and the standard V50 (3 gears) transmission. Only I have the selector for the 50s transmission and not the pk or are these the same? When I use the selector of the 50s I have a little difficulties in the neutral. Because the neutral of the 50s gearbox is somewhat wider.
I wanted to have the 50s transmission to have low rpm in the fourth gear. My setup is a 70cc cilinder with a SHB 16.16 and standard exhaust. And I want to have a cruising speed around 60-65 km/h.
I’m not planning to spindle the case to 54mm what is the advantage of that?
So you would recommend using pk instead of 50s gearbox or maybe even the standard gearbox? Or is it both possible? With the 50s I have to alter the case or is that risky anyway?
    • Is das mit HD140 und S&S Prüfstandsbedüsung oder fährst du das so auf der Straße?
    • Beschreibung: Ich suche eine MMW Bremspumpe fuer meine 1965 Lambretta LI Special 150 (Series 3). Bild als Referenz. Preisvorstellung: Je nach Zustand - Versand nach Berlin
    • Hallo,   Schönes Topic @px211  Ich habe eine Frage zu deiner Grundierungs-Aufbring-Methode. Du schreibst "tupfen". Wie genau bringst Du die Farbe zum Beispiel auf die Backe auf? Klebst Du alles akribisch ab und sprayst die Farbe, oder rollst/pinselst oder tupfst Du die Farbe auf?   Vielen Dank im Voraus
    • Wie kommt der Wert Zustande?   Wenn du aus niedriger Geschwindigkeit im 4. gab durchbrschleunigst, ist das quasi hohe Last. Da Magret ein Keihin z.b. immer kurz ab bzw taucht in Richtung mager weg.   wenn ich 120 fahre konstant hab ich 12.9-13.5 je nach schieberstellung und nadelposition.  Halte ich voll drauf, steht da ~12.5-13.5 auch je nach Last
    • Da hast du natürlich recht aber hier wurde ja genau das vergessen, so hier beschrieben wurde. Natürlich bleibt immer ein gewisser Rest an Öl zurück wenn es abgelassen wurde, aber ob die Menge dann tatsächlich noch reicht um durch den Siri gezogen zu werden halte ich hier dann für fraglich. Dazu gab es die Angabe ca 5 bis 8 km ohne dem Getriebeöl gefahren zu sein.   Im Vergleich zu denen die hier weitaus mehr km ohne unterwegs waren, muss da schon zuvor was nicht mehr gestimmt haben.  Aber deshalb meinte ich ja, dass hier überprüft werden sollte, was hier wirklich nicht stimmt. Ich zitiere mal eine Aussage von einer Person, die ein Fahrzeug verkaufen wollte wo der Motor fest war. Diese wußte nicht, wieviel Öl dem Benzin beigemischt werden musste. Und was hast dann da reingekippt? Nichts..  Passt vielleicht nicht ganz hier, aber ohne den Motor jetzt mal abzudrücken bleibt hier alles weiter im Nebel..
