[High transfer - high exhaust] VS [high transfer - low exhaust]
GiulioEX125E
Hi everyone, first of all excuse me for writing in english, but I don't speak german :rotwerd:
I have a question about cylinder timings, I would like to discuss it in a "unspecific" way, without mentioning any specific cylinder brand, carb type, exhaust, etc.
Let's say I have an engine that has 130-190°. This is the power/torque graph:
31.5 hp @ 8500 rpm
26.1 nm @ 8200 rpm
From general knowledge, if I simply lowered both the transfer and the exhaust (let's say 125-185°), the torque band would move to the left, giving me more torque at lower rpm but also less peak power and less over-rev.
Now: how would this curve change, if instead I only lowered the exhaust? Let's say, from 130-190°, to 130-180°? How does lowering the exhaust only, affect the curve?
If I lower the exhaust only, it probably won't be exactly like I just described for lowering both transfer and exhaust, right?
If someone here already experimented this combination (high transfer-low exhaust), feel free to draw on my graph to show how you think the curve would change.
Bearbeitet von GiulioEX125E
  • GiulioEX125E änderte den Titel in [High transfer - high exhaust] VS [high transfer - low exhaust]
Here is another test with a change the Blowdowne.
the same i test on Polini 177 and Malssi MHR with the same effect.
26°-28° in my experience, that's enough for the road.
depending of Setup.... so you have more power from below.
for pure top performance you can go more than 30 °.
but then you often lose more power in the lower area than what you put on top.
@AIC PX
I couldn't find anything related  to my question, in those 2 topics :(
You surely tested a lot in terms of cylinder timings, but I didn't find a test where you only lowered the exhaust, keeping the transfers at the same level. You tested blowdown changes but in all the tests, you also changed transfers...
