hello
have dificult in adjust the ignition per cicle in tacho SIP. in adjust 2 or 3 always do more revs than engine .
can you help
regards
@edumegacc Take a look at the SIP Webshop, on speedo page is explained how to adjust the rev counter if combined with AC vape ignition…
You habe to connect white Vape CDI cable with brown Speedo cable, and adjust rev counting signal to 6…
look here:
good morning
i allready install sip vape DC and use koso filter and conect to spark cable and works perfect.
With sip vape AC i thing that clamp light wire to brown will do the work. the information to clamp white wire cdi to brown is not for DC version?
thanks
I think you‘d better ask at the SIP Hotline to get that information… I’m not sure if it is only for AC Version…
Bearbeitet von OFFI
Korrektur
good morning
just to give the feed back
in adjustment 4 from sip tacho choose position 6. the brown conect to light wire. RPM works great.
regards
