Verschieden SF - Anti-dive /T5 Gehäuse / GPS Zylinder / Hammerzombie
gommon
Hi,
I'm selling some of my CNC parts (my property).
The items are located in Lisbon (Portugal) and can be shipped to anywhere in Europe at 7/8€ cost .
The parts are brand new. Maked by myself.
Anti-dive kit.
(1x) CNC machined swing arm ( Aluminium Series 5)
(1x) Special Shock mount screw (Stainless steel)
(1x) M8 screw (stainless steel)
Prices (except shipping costs)
Aluminum CNC machined swingarm  ( without anodization )= 60€
Aluminum CNC machined swingarm + natural anodization = 65€
Aluminum CNC machined swingarm + black anodization = 70€
(Can be anodized in other colors by request, ask by message for quote)
thanks
8.thumb.jpg.8f8ec86853875f3b0cd84b135e3a5756.jpg.61bcee71c97e4d207295edbefa5eaa1c.jpg7.thumb.jpg.7935ca811801d1bde6ef86768d874546.jpg.169a420934e91b9cd40cc8e76c512b3d.jpg
6.thumb.jpg.be951596a62d3b6dcfdbeab838789892.jpg.13e72cd9ded83b512fcfec5d6d74d235.jpg3.thumb.jpg.70e1dec9d633b0474a1e51ba973fc7ff.jpg.a87dafe796caaed66ebb6e98a36dcdb6.jpg
Thanks and best regards
G.
  • gommon änderte den Titel in Cagiva/Gilera Zylinder " Angelo Zirri" oldschool 80/90"
  • gommon änderte den Titel in T5 Gehäuse (98M)
T5 cases (without number) welded and milled.
The cases are mine and stay in my garage in Lisbon (Portugal)
-Matching numbers on top,
-Welded, milled dia.76mmx15 to fit YZ250 cylinder, complete, no damage,
-Rotary valve milled to reed.
Was cleaned by glass pearls
300  290€  250€ (including shipping to all Europe)
Possibility to exchange with Quattrini C200 cases ((+ money from my side)
10 minutes ago, weissbierjojo said:
you have cleaned the seats of the bearings too??
No, the bearing seats where closed with old bearings. Removed after cleaning.
you can see one of the old bearings (gears) still in the case.
  • thisnotes4u änderte den Titel in T5 Gehäuse (no number) + T5 Gehäuse (98M)
  • gommon änderte den Titel in SF Anti-dive (anti afundo) parts
  • thisnotes4u änderte den Titel in SF Anti-dive (anti afundo) parts / T5 Gehäuse (no number) + T5 Gehäuse (98M) / Cagiva/Gilera Zylinder " Angelo Zirri" oldschool 80/90"
  • gommon änderte den Titel in SF Anti-dive parts / T5 Gehäuse / Gilera Zylinder " Angelo Zirri" oldschool 80/90"
  • gommon änderte den Titel in Verschieden SF Anti-dive /T5 Gehäuse / GPS Zylinder
Selling a new GPS cylinder from "dierollerfabrik", rare item.
- Cylinder 60x51 (new)
- Diaphragm (new from Falc)
- Inlet 30mm (used in other engine)
- Piston (new), missing pin and circlips
250€    240€ shipping cost included (to all Europe ) Gone!!
  • gommon änderte den Titel in Verschieden SF - Anti-dive /T5 Gehäuse / GPS Zylinder / Hammerzombie
  • 3 Monate später...
    • Als Außentemperatur Anzeige hatte ich das auch an meiner PX
    • Von Bautechnik hab ich jetzt nicht wirklich Ahnung, aber meine erste Idee wäre in den Beton Stehbolzen einzusetzen, diese abzudichten und dann das Brett oben drauf. Die Mutter im Brett versenken und dort auch wieder Dichtmasse drauf damit kein Wasser in den Senkungen stehen bleibt.   Wenn man dabei mit einer Bohrschablone arbeitet sollten die Stehbolzen und Bohrlöcher flüchten.   Wie gesagt, nur ne Idee..
    • So sehe ich das auch…. Ich kenne niemanden, der ne eingetragene Scheibenbremse hat und dann wegen der Gabel Probleme hatte.    wenn jemand wirklich vor hat, den Roller erstmal stehen zu lassen, dann wird das bei dieser Sprint hier schnell gehen, aber nicht wegen der Gabel. Ich habe die Erfahrung gemacht, dass hier zunächst auf den Motor geschaut wird. Wenn dann an den Teilen nicht draufsteht was draufstehen soll, ist Ärger im Anmarsch. Und abzulesen, ob da keihin oder mikuni draufsteht, das bekommt man auch ohne große Kenntnis hin.    die Idee so zu fahren, finde ich nicht schlecht, wenn das so passt würde ich alles dann legalisieren, wenn möglich.
    • Moin,   wieder startet die Suche nach einer Lokalisation für den nächsten Wurst-Termin am 04.03. um 19hundert.   Ideen und Vorschläge sind gern gesehen!
    • Bin mal bewußt einen Winter hindurch täglich zur Arbeit (10km einfach). Egal wie kalt, solange kein oder nur wenig Schnee lag. Bei -10 wurde es arg ungemütlich. Da fror das Pinlock Visier von innen ein.
