Serveta Lince 125 - SOLD
chocolate
Hello all, I am selling my 1985 Serveta Lince 125.
I imported it from Spain in 2014, took it apart and rebuilt it only with good quality parts over the years taking my time. This project is finished since years but I have other scooters so I only enjoyed it for around 700 kms. I decided it’s time to let it go, it deserves to fulfill its destiny …
Everything has been refurbished with no compromise, the list of parts changed and upgraded would be too long to enumerate but to summarize :
- Chassis :
  • Chassis and fork sandblasted and painted with a strong coat of epoxy
  • Body panels in original paint
  • Fork rebuilt, MMW brake disc kit and Stage 6 radial caliper
  • New Sx handlebar (probably from Asia), Formula master cylinder
  • Gamma RTSE1000 monitoring (speed, rpm, odometer, CHT, EGT) installed on legshield toolbox
  • Oiltek long range aluminum tank 16 liters
  • Protech rear shock
  • Homemade battery holder
  • SIP tubeless rims with Heidenau K58 tires
- Engine :
  • Imola cylinder kit (latest version) >> diagrams 125/179, squich 1.4mm, CR 9.15:1
  • BGM 58x110 crankshaft, Yamaha conrod
  • Scootronic 12v DC ignition with AF Rayspeed lightened flywheel
  • Casaperformance chain tensioner
  • MMW 7 plates clutch
  • Li150 gearbox (16x46)
  • BGM V4 exhaust
  • PHBH 30 carb with CTS filter
Pros :
  • Smooth engine, handle great and very easy to use with a soft clutch lever
  • Front brake is very impressive, thank to the anti-dive system and the radial setup
Cons :
  • The front end may be a little bit too stiff because of the reinforced fork springs
  • The rear indicators are not connected because as soon as I plug them it blown the fuse … the relay may be faulty, but I am not an electronic expert unfortunately and I quickly gave up as I don’t use them anyway
  • The speedometer is a repro, a weird noise appears recently while driving … I have still the original one which is fully functional I can give or replaced if you want
The scooter is located near Paris.
You can find a quick video of the scooter following this link : https://www.youtube.com/watch?v=eo1oN4X39Lo
Asking price : 5200 euros, can be discussed 😉
If you have any question, feel free to ask !
  • chocolate änderte den Titel in Serveta Lince 125 - SOLD
  • thisnotes4u hat Thema gesperrt
