Falc 54/105 crankshaft, L&S 55er exhaust, Dellorto VHSB 34, Parmakit SP 8 ignition kit
Marko73
Hello, I sell the following products:
Falc crankshaft kit 54mm stroke and 105mm connecting rod.
Balance factor 44% with 60mm Falc/Polini piston, 380e
The crankshaft I bought direct from Lauro in 2007
Ludwig&Scherer 55er exhaust, 290e
Dellorto VHSB 34, 160e
Parmakit SP8 ET3 ignition kit, cone 20mm. Eight pre-programmed advance curve.
Flywheel weight 1,1 kg, 240e
Parts have never been used or assembled.
Location Valkeakoski, Finland
Bearbeitet von Marko73
  • Marko73 änderte den Titel in L&S 55er, cnc flywheel for Vespatronic.
  • Marko73 änderte den Titel in Falc 60x54 cylinderkit, Falc 54/105 crankshaft, L&S 55er exhaust
  • Marko73 änderte den Titel in Falc 54/105 crankshaft, L&S 55er exhaust, Dellorto VHSB 34, Parmakit SP 8 ignition kit
