30th Challenge Scootentole & ESC - Mirecourt 11th of May 2024
KTy
Registration on https://www.eurochallenge.de/
Scootentole presents the 30th Challenge Scootentole -:wheeeha:
https://scootentole.org/phpbb3/download/file.php?id=19536
As usual, track will be accessible for training on Thursday, Friday and Sundayxx€ half-day and xx€ full day (payment on site). For these 3 days, you must have your own insurance or you get one on the spot (from the track).
Practice on track will be available (15min sessions) alternatively with go-karts and/or with motorbikes
:gsf_chips:
Categories and podiums (to be confirmed)
  Quote
- K1 (C3-1)
- C3-2
- K3 (C2L)
- K4
- C4 (former old largeframe K4)
- K5 (C2S)
- K6 (C1)
- K7 (C7)
Planning (To be confirmed)
  Quote
Roulage - 20 minutes
8h30: K6 + K7
8h50: K5
9h10: K1 + C3-2
9h30: K3 + K4 + C4
Qualification 1 - 20 minutes
9h50: K6 + K7
10h10: K5
10h30: K1 + C3-2
10h50: K3 + K4 + C4
Qualification 2 - 20 minutes
11h10: K6 + K7
11h30: K5
11h50: K1 + C3-2
12h10: K3 + K4 + C4
12h30. GROUP PICTURE
12h30-13h30 Pause déjeuner / Lunch Break
Course 1 - Race 1 - 10 minutes + 2 laps
13h30: K6 + K7
13h50: K5
14h10: K3 + C4
14h30: K1
14h50: C3-2 + K4
Course 2 - Race 2 - 10 minutes + 2 laps
15h10: K6 + K7
15h30: K5
15h50: K3 + C4
16h10: K1
16h30: C3-2 + K4
Course 3 - Race 3 - 10 minutes + 2 laps
16h50: K6 + K7
17h10: K5
17h30: K3 + C4
17h50: K1
18h10: C3-2 + K4
Best of All - 10 minutes + 2 laps
18h30: 5 best of all racing categories
Followed by:
  • Podium
  • Lucky-draw
  • Apero !!!    :cheers:
Food and drinks
There will be possibility to eat on the spot, usual BBQ, french fries, etc
* Lunch (main dish, drink, coffee): TBD
* Diner coupon (Salad, meat, fries, drink, coffee): TBD
Location of the track :
As a reminder, the track is in Mirecourt (France, 88) and it is not so far from the German border; get direction: http://maps.google.fr/maps?f=d&hl=fr&geocode=4052204080919766249,48.319569,6.077357&time=&date=&ttype=&saddr=&daddr=Circuit+de+mirecourt%4048.319569,+6.077357&mra=pe&mrcr=0&sll=48.274054,6.019135&sspn=0.18783,0.398254&ie=UTF8&ll=47.931066,6.679688&spn=6.050603,12.744141&t=h&z=6&om=1
http://www.freekart88.fr/images/circuit.jpg
A twisty, technical yet fast track in perfect condition, 1250m x 8m, fully equipped !
  • 3 Monate später...
    • Nicht ohne sehr aufwändige Umbauten. Am einfachsten ist ein Schalter den man unter der Sitzbank durch das Vordere Loch zieht. also nix bohren. Ansonsten kann man das hinmachen wo man will. Handschuhfach Innen oder Aussen, Rahmen zb wo die Rally mal den Kill hatte. Man sollte sich halt überlegen wie praktikabel das Ganze dann im Betrieb ist. Also wenn ich nur am Sonntag mal an die Eisdiele fahre kann die Bedienung schon etwas umständlicher (dafür der Einbauort versteckter) sein. Wenn ich damit täglich fahre würde ich keine Position haben wollen an die ich nur umständlich ran komme.
    • Hier mal die erhältlichen DU- Buchsen, masslich gleiche Ausführungen erhältlich, nur mit anderer Beschichtung 10x12x10 10x12x15 10x12x20 10x12x25 10x12x30   pr
    • vielleicht M8er Schrauben? Was denn jetzt das Problem? Muss man doch nicht kaufen wenn man das kacke findet....
    • Wenn ich die Bedenken von @wladimirbetreffend Festigkeit des Gusses im Bereich weiter unten im Bereich der Achsenführung teile, bin ich voll bei @wladimir! Das ist ein Aspekt der eigentlich nie ins Auge gefasst wurde, man darf die Hebelkräfte die da wirken nicht unterschätzen. @karren77hier mit dem RiKuLa 10x15x4 nochmals mehr zu schwächen würde ich Abstand nehmen.   In Richtung mehr Festigkeit, wie es sich @wladimir ausmalt und wünscht, würde ich immer noch auf Buchsen mit max. 1mm Wanddicke setzen. Oben am Block für die Aufnahme des Siri spindeln, hier den einzig erhältlichen Siri mit Spirale verbauen.   Manchmal muss man einfach nur eine Nacht drüber schlafen, um es wie Schuppen von den Augen fallen zu lassen!!   Dann nochmals ganz lapidar gefragt betreffend den Buchsen, warum nicht ganz einfach die als Katalogware erhältlichen "DU- Buchsen" mit 1mm Wanddicke verbauen??  Mit den verschiedensten Beschichtungsmaterialien in der Lauffläche erhältlich.   Bei noch nicht eingelaufener Schaltwellenachse, sprich "neu", sogar dauerhaft verschleissfrei laufend, auch mit nicht gehärteter Achse!   In sehr vielen Längen erhältlich, bei Überlänge kürzen problemlos möglich und zwei Buchsen in Reihe zu setzen auch kein Problem. Grundbohrung in 12H7 herstellen
