ok...I had a look at the link and found this:
Spannungsregler PX/Lusso/T5/
PK50/FL/HP/N/Elestart/XL/Cosa2
m. Batterie/Blinker, 5 Anschl.
VLX1T 157959-/VSX1T 33625-/
Art.-Nr. 85150000
Gewicht: 225g
Mengeneinheit: Stück
(VMX5/V8X5/V9X1/V5S1/V8X1/VLX1/VMS1/VAM1
/VA81/VA52) 3000001-/VNX1T 81784-/VNX2T/
V5P1-2/V5N1/TL6T 20001-/TL3T 500001-/
FCS1/NS81/NSL1/NSP1
V9B (USA/PR/CDN)/V8X1 (D)/(VNX1T 75590-/
VSX1T 34627-/VLX1T) (USA/PR)/SP81 (CH)/
V5X2T (A/D/GB)
Art.-Nr. 85150000
Gewicht: 225g
FCS1/NS81/NSL1/NSP1
V5X2T (A/D/GB)
<{POST_SNAPBACK}>
yes, I'd seen my pxe vnx2t in that list.
But what is it for ?
there are no voltage regulator in a pxe ?
<{POST_SNAPBACK}>
nobody has an idea ?
Richard, the creator of http://www.vespamaintenance.com/elec/charger/index.html
says
"The Voltage Regulator / Rectifier on the P200 is a black box that performs two distinct funtions withing the same box. The first function is battery charging. The battery on a Vespa requires constant charging in order to run many of the indicators and safety features of the bike (and starter motors is your bike is so equipped). The second function of the regulator is to regulate the AC power for the headlight and spedometer light. The regulator/charger box is probably the most advanced collection of circuits on the bike, but it is the least prone to failure"
This part should be fitted as standard already on the models whose vin-prefixes have been mentioned - your scooter already has one. Which means that the part you mentioned is just a spare part to replace the one that has been fitted originally (in case it has blown up).
So if your scooter´s electrics work fine - no need to change or add anything, especially when it comes to electrics.
Bearbeitet von sidewalksurfer
