sorry i have to go in englisch my german is not so good
what is the diference between the brake drum from a vespa with the oil seal inside the engine and a brum with the oil seal on the outside of the engine
if it coud with the mesurements
thanks sidvespa
the drum for a "seal inside engine" has not necessarily a face for the seal to run on, most of them have a rough cast surface there - a drum is typically for a "seal outside engine" if it has a machined surface for the seal to run on.
