  • Antworten 398
sehe schon..lang lang ist es her mit den "laubsäge-arbeiten" im KiGa,was?? :-D
aber da gibts schone feine/dünne blätter.... :-D
gruß
Tom
gruß
Tom
<{POST_SNAPBACK}>
Die dünnen Blätter bekommst Du auch beim nächsten Goldschmied oder Goldschmiedewerkzeughandel (Branchenbuch) in Verbindung mit einem ordentlichen Sägebogen (Qualität) und viel Übung (alternativ viele Sägeblätter) funzt das super!
LG Marcus
I have a few questions regarding the advantage of a Einlass Rießengroß....
When using a mrb like housing, were are the flow from the tip of the reedcage aimed? How large is the crankcase volume?
Would there be any advantage of welding on a mrb housing instead of bolting it? I don't think so, what do you mean?
With a welded or bolted on inlet, like PBS, stroh, S&S etc. Were are the flow aimed? How large is the crankcase volume?
I would assume that there is a measurable difference in crankcase compression between a mrb or a pbs system?
But are there any restrictions in the flow capabilities of the engine when looking at it as a whole? The word CVF is ticking somewere....
Wouldn't the only improvement over the two types only be increased crankcase compression? The flow travel path? Crankcase volume?
There is a paradox here somewere but I don't know how to find it?
I've seen dynographs of the same engine with both mrb and S&S inlet. (S&S homepage). There were no significant increase in max power, or torque. It can be discussed if a 10% increase in low end is worth a loss of 1200rpm overrev. Crankcase compression characteristics?
The optimal performance of the inlet would be a sufficient and as short flow travel path as possible. There is no need to overadvantage the size of the inlet or membrane, this is also somehow linked to carburetor size I think. Would also think that the crankcase volume is of importance, the compression only alter certain characteristics?
Can someone give me some facts?
cheers
truls
.... mir gefällt die lösung verdammt gut ... und ist für viele varianten anwendbar ....... vorallem kann man diese stufferteile nach belieben austauschen wenn mal ein strömungsmuster daneben gefräst wurde .......
ja also gehört der motor dem mizi?
<{POST_SNAPBACK}>
Sorry, soll das ein Witz sein? Das steht schon 10 Mal hier im Topic, und per PM hab ich dir auch gesagt du sollst dich bitte an den Mizi wenden da es sein Motor ist!! Alder :plemplem:
ich werde versuchen das ganze hin zu bekommen ohne irgendwas oben raus zu machen, obs geht wird sich am Freitag Mittag zeigen, aber eigentlich müsste es mit einer 3D fräße machbar sein, blos sicher versprechen kann ichs ned.
MC
MC
<{POST_SNAPBACK}>
hi
und wie siehts aus?
funktionierts?
gruß Darkstar
@ darkstar was isch los meld dich mal dass man das klar machen kann
@all heute Mittag gibts Bilder sieht schon super brauchbar aus. Größere fläche blos zum fräßen komme ich dieses Wochenende leider nicht mehr.
Nur zur Info also über zweiseiten Einlass habe ich nochmal nachgedact, mir isch das zu dumm, ich werd jetzt was sauberes einseitig machen, weil die arbeit steht in keinem Verhältnis zu dem was nachher mehr raus kommt
MC
Hier vielleicht auch noch mal ans Anhaltspunkt interessant... habe uebrigens ne kleien Puk Saege genommen um den Kanal rauszutrennen. Das U Stueck ist mit Loctite eingeklebt und dann verschraubt.... haelt bombenfest und dicht!
Groesse Loecher *g*
und als Leckerli schon mal ein Bild
Ist uebrigens fuer ne Mito Membran
so bin auch wieder in den landen.
war mal wieder bissle lang im Urlaub.
das was der metzler da schönes reingesetzt hat isch ja mal gar nicht so übel, aber ziemlich, na ja, sieht lecker aus aber sicher nicht das optimum was machbar isch, ich hab mich dran gemacht und hab das ganze jetzt mal entwickelt und heute mal schon bisschen gefräßt und so weiter ich werde euch vielleicht heute mittag oder heute abend mal ein paar bilder offenbaren die euch vielleicht überzeugen.
Jeder den ich bis dato gefragt hab, hat zu mir gesagt es wäre nicht nötig nen beidseitigen Einlass, aber wenn man überlegt, was man da für ideen verarbeiten kann! Also ich bin jetzt auf dem Weg dahin, dass die Membran im Endstadium nur noch 0,2mm Abstand zur Schali hat, was ja eigentlich ned übel ischd.
@ der Metzler. haschd du den Einlass gemacht oder hast das irgendwoher ausm Netz?
@all: vielleicht mach ich da ja bald nen ganzen BAusatz draus, den man für billig Geld bekommen kann, hat denn jemand interesse?
MC BEsserwisser
<{POST_SNAPBACK}>
Aufpassen dass die Plättchen im Betrieb nicht die Welle berühren, im Zweifel lieber nen Tick höher setzen. Bin gespannt auf die Bilder...
Hm,
also gerade bei ner Schali-Welle würde ich die Membran lieber nicht so nah an die Welle setzen!
Hast Du Dir schonmal Gedanken darüber gemacht, wie sich die Gasströmung unmittelbar hinter den Membranzungen ausbildet?!
Die ist da sowas von chaotisch-turbulent, dass einem schlecht wird!
Und wenn dann noch so ne Verwirblungs-Welle da vorbeirauscht, hätt ich bedenken, dass Du Dir damit ganz gewaltig Störungen einhandelst...
Wenn Du schon so dicht ran willst (und über beide Hälften) dann ist meiner Meinung nach ne Vollwange - natürlich sinnvoll bearbeitet - Pflicht.
Aber stell mal bitte die Fotos rein, dann kann man sicher mehr sehen/sagen.
Frohes Fest!
Gruss,
Alex.
P.S.: bitte schreib nicht immer Dialekt....
und was isch jetze mit deine 3D fräße?
hasch scho was gmacht?
gibts bildasch?
PS:
haschte echt die kiste so gelackt?
Bearbeitet von gravedigger
    • So...mal einmal ne leichte Nadelumsetzungs-änderungsrunde gedreht. Der PHBH rotzt echt bißchen im Stand an der Ampel zu. Da ist dann ein oder zwei Gasstöße gut zum Anfahren.    Ansonsten lief der PHBH jetzt schon ok'ish.   Hab dann aus der Laune heraus den VHST28BS draufgebaut. Der lief erst mal doof. Dann gemerkt, dass der Choke leicht gezogen wird. Der war zu stramm. Dann wars besser, aber schlechter als der PHBH. Dann mal einfach nur die D29 Nadel eine Kerbe weiter nach oben. Das Ding fährt nun ziemlich fies. Mit 2.62er Primär geht der ohne Gasgeben einfach im zweiten Gang hoch, wenn der in Reso geht. Bertha ist echt ab ca 6-6.500 U/min immer noch ein geiler Auspuff! Das hat mich echt beeindruckt. Hatte vorher nen Parmakit non-SP09, VHST24, Drehschieber und PM40 drauf mit GSFDyno 17PS. Das hier mit dem ET7 ist deutlich fieser. Werde ich hier auch mal checken.   Was mir an dem VHST einfach immer wieder super gefällt, ist das Ansprechverhalten und das weniger bis kein zurotzen an der Ampel. Klar...ist nur ein 28er, aber der läuft einfach wirklich immer fein. Leerlauf fällt super schnell wieder auf 1000-1100 runter. Das finde ich einfach super geil!   Wie @alfonso schon immer schreibt, passt beim VHST, egal ob das der 24er (HD kleiner dann) oder 28er ist, folgendes mit nem guten Reso (Franz/Bertha/etc...) gut:   Nadel D29 2 Kerbe v.O. Schieber 45 HD140 gemessen (Dellorto 130 steht drauf) - Kein Luftfilter AQ264 Leerlauf S35 Chokedüse 60   Setup ist:   Zylinder VMC ET7 (190,4/131,6/VA 29,4) QS 1,15mm Kurbelwelle DRT 53/105 ETS Vergaser VHST28BS mit MR Ansauger Drehschieber 207°(140°v.O.T./67°n.O.T.) Zündung Ducati 1350g 17° geblitzt abgedrückt und dicht Big Bertha mit Aprilia RS Dämpfer MV PK75XL Gehäuse   Damit mach ich jetzt weiter und geh jetzt in die Feinabstimmung. Den PHBH bau ich nicht mehr drauf  Ich schätze mal, dass ich mit nem Luftfilter bei irgendwas gemessene 130-135 landen werde.    Ich berichte
    • Du hast die Kolben ausgebaut und dann wieder eingesetzt?    Die Kolben bzw. Zylinder sollten vor dem Einsetzen "geschmiert" werden. Dazu gibt es Bremszylinderpaste z.B.:  https://techmol.de/Bremszylinderpaste-Techmol-Tube-50g-DOT3-DOT4-DOT-51-bestaendig
    • Sicher O-Lack? Dachte VNC1T gab es nur in weiss laut diversen Quellen. Bilder von der rechten Seite und vom Trittbrett unten wären toll. VG
