Wide Tire kit, swingarm and shocks
rlaspina
Hi there!
Sorry I do not write german, hope somebody can help.
I am planning to mount a wide tire kit (2k) from Sip with 130/70/10 tire for my P200E. Now I understand that with this kit you need to cut 10mm off the swingarm and add a spacer of 10mm on the other side. I have read on a few forums that to have the rear wheel exactly in the center you actually need to cut off 17mm and add that to the other side. Can anybody confirm this?
Does anybody know if my bitubo in the back is still going to work OK if it is not haging strait anymore? will it brake at certain point?
If I move my engine out 17mm will I still be able to put my engine cover on?
On the front (with bitubo and semi hydraulik disk brake) will a 110/70/10 fit without modifications? If not which one does? Can I use the standard Rim (2.50/10)?
Thanks!
If you move the motor more than 10-13mm you will have to modificate the motor-cover!!
If you have an Polini or Original cylinder you will not have any chance to enjoy riding on your PX 200 because the right side is to heavy for a good movement on the street!!
If you have an aluminium-cylinder, thats no problem!!
I ride a 120/90-10 tire and i have a little diffrent in the line of the two wheels, but that´s not much and it´s no problem!!
Hope I could help you!
Ivo
