Moinsen,
vermutlich bekamen mehrere hier die eMail von ScootRS, in der der Laden anbietet, zwei Scheibenbremskomponenten (Bremspumpe und Sattel) gegen höherwertige japanische Artikel ein-/auszutauschen. Den Kunden, die in Frage kommen, wird ein recht günstiger Kurs für diese Upgrades angeboten.
Habe eh oben die Grimeca-Pumpe und Richtung Bremssattel noch keine Ahnung, was abgehen wird.
Wer hat in irgendeiner Form schlechte Erfahrung mit dem Sattel (pissende Dichtungen o.ä.) gemacht und rät zum kostenpflichtigen AT?
We want to let you know that we now have a new version of our disc brake kit. The new and better version uses original Japanese hydraulic components, the master cylinder and caliper. The old one used aftermarket components which was all we had a supply of before.
» » For past customers of the old kit or components, we have a heavily discounted price if you want to retroactively upgrade.
Why upgrade? Despite our best efforts to rectify supplier problems a small percentage of customers have reported that the aftermarket components at some point lose pressure because of a seal or some small manufacturing variance and need to be rebuilt/replaced. If that was your case, we do apologize. We took several steps to fix it, to the point where we now completely rebuild and test each aftermarket component, thus reducing any issues dramatically. Most are fine, but now that we have the Japanese components, we recommend that version and expect zero issues with them. (For now we will list 2 versions of the kit, as the Japanese components are much more expensive, but if we see everyone is OK with that, we'll only offer the better one.)
If interested, see this Bremse upgrade item onsite. You will need your old order number.
scootRS Lambretta Vespa Scooters and Parts Manufacturing ~~
we manufacture cool ~~
126 Leser dieses Posts während der ersten Stunde und 30 Minuten. Rekordverdächtig :-D:-D;-)
Bearbeitet von M210
<{POST_SNAPBACK}>
wir haben ein Kit bekommen, bei dem die Bremszange irgendwo Luft gezogen hat. Ein kurzes mail an scootRS und 3 Wochen später war die neue Zange da, die bislang einwandfrei funktioniert (etwa 4 - 5000km).
Wie viel sollen denn die Japsenteile kosten?
Also die Zange funktioniert/e bei ca. 10-12 Bremsen ohne Probleme. Handbremszylinder kann ich nichts zusagen.. Finde ich scheiße und neheme immer Grimeca teile...
Markus
Ich hab noch vor Weihnachten bei Scootrs bestellt und auch deshalb auch gleich das upgradekit für die Scheibenbremse genommen.
Die Teile sehen gleich aus hab bis jetzt aber noch keinen vergleich gehabt.
(Kommt erst am Wochenende)
der einzige ersichtliche unterschied ist das auf Geber und Bremszange Nissin oben steht
Meine bestellten Teile wurden am 07.01.05 abgeschickt, Waren am 10.01.05 am Zoll Schweiz und wurden am 11.01. zugestellt... und ich war gestern natürlich nicht zuhause... :-D( werd sie heute beim Postamt abholen... :sabber:
Falls mal wieder wer bestellt...- bräuchte das Upgrade auch, möchte deswegen aber nicht die Vietnamesen stressen. Würde mich gern bei einer Bestellung x-beliebiger Teile anschließen.
Ist das NISSIN geprägt oder gedruckt odda wodda?
