  • Antworten 92
Also ihr habt mich nun soweit gebracht das ich entweder gar nichts mache oder aber mir das gesamte AF Flywheel Kit mit 12V Umbau kaufe.
Ist günstiger als die Varitronic und sicher auch nicht schlecht oder?
Hat von Euch jemand das gesamte AF Zündungskit eingebaut? Läuft es problemlos? (Werde hoffentlich einen Elektonauten finden für den Umbau).
<{POST_SNAPBACK}>
Darf ich auch mal :-D ...aber bemüh mal die Suche...
<{POST_SNAPBACK}>
Vermutlich liegt beim Kauf eine ausführliche Einabuanleitung bei.
nach der missglückten bohrmaschinen theorie & dem von TV200 empfohlenen werkzeugset: LASS DIE FINGER VON DER LAMBRETTA!!!
nimm dir doch ne schöne neue VESPA GT 200, dann kaufst du dir schön piaggio zubehör & bist der GQ-SUPER-MOD.
So Spass beiseite,
The Technology
The Standard Indian Electronic Flywheel weighs 2650g. This weight gives the engine considerable momentum, aiding the smooth running of the engine. This increased inertia allows the engine to perform better under load so is better suited for people using their bike with a pillion or heavily loaded with camping equipment.
The AF Light Flywheel weighs 1380g. This reduction in rotating weight gives the engine quicker responce, providing improved acceleration with increased top speed. The difference is immediate and noticable even on a standard machine. In combination with a performance engine this can provide a significant edge.
This Light flywheel is especially suitable for use with high reving expansion systems such as Our NK Pipe, the PM Pipes and the JL Race Pipe.
Fitting the Light Flywheel to an older stator plate
For those customers who have bought the flywheel alone and are planning to use it with an existing electronic kit.
It has come to our attension that although our Light flywheel will be a straight swop for most people currently running an electronic kit, some patten stators of indian origin will require a modification to the low tension coil as per the photo.
This is due to the low tension coil being taller than standard leaving insufficient clearance between the low tension coil and the rivets of the rotor.
This modification is easy to carry our if you have a good quality soldering gun and small file. Alternativly if you send your stator plate to us we can carry out this modification for £5 + P&P.
Link und Link
Ergo, passt bei dir nur mit Variante a) oder du kaufst das komplette Kit. Was sind schon 60GBP für die restlichen Komponenten...
Ob du diesen Krams brauchst solltest du selber entscheiden, je nach deinen Fahr- und Lusteigenschaften. 12V ist ein Argument, zählt aber nicht bei dieser Kombi.
Aber lies mal oben und dir wird auffallen, die Leichtigkeit brauchst du nicht. Andere schon eher...
-Soul
<{POST_SNAPBACK}>
oder warum nicht diese schöne :-D S.4 Lambretta???
Servus Rudi,
fahrs orginal - mei SX200 und die LiS 125 laufen einwandfrei mit dem normalen Lüfterrad und der Unterbrecherzündung. Nur bei Umbau auf z.B. Honda 205 könnte ein Umbau sinnvoll sein, jedoch nur wegen des dickeren Stumpfes der Gp Welle nicht wegen dem Unterbrecher. Des Ding links im Advar läuft auch mit U-Kontakt.
Ciao
tom
PS. Was machtn mei GS?
@ soulist:
also soulist danke für die super info, respect to soul!!!! würde dich am liebsten auf ein bier einladen, aufgrund der antwort!
@ tom:
der GS gehts optimal. elektrik wurde von einem abchecker gemacht. funktioniert nun alles einwandfrei. fehlt nur noch schwanenhalslicht. übrigens verkaufe sie wahrscheinlich wieder um mir noch eine Lambretta zu kaufen, falls sich was ergibt. seit ich meine SX habe, bin ich nicht mehr so scharf auf Vespe. Ist einfach geiler zu fahren und gefällt mir auch besser.
Falls du einen Interessenten weißt hier der Link:
www.tret-roller.at (steht glaube ich um 2.300 drinnen - Kommissionsverkauf)
Besten Dank noch mal! :-D
P.S. Bevor ich mir eine GT200 Vespa kaufe fahr ich lieber Skateboard bzw. kaufe mir eine KTM Supermoto das mach wenigsten wirklich Spass!
Das geilse wäre sowieso ein KTM Motor in einem Lambrettagehäuse, das wär schon was. Der KTM Designer wohnt bei mir ja um die Ecke werde Ihn mal drauf ansprech. :sabber:
Bearbeitet von Remod
So Spass beiseite,
<{POST_SNAPBACK}>
wow cool! luck gayhabt remod! that fits yes doch! than i am excuse me at you & you gibst me exclusive your hausseitennamen!
regards steve
Remod, nichts für ungut, hier noch die Varitronic
dir Wesentliches:
On standard cylinders and some types, power may not be gained, but you have the benefit of a high quality reliable system that is not prone to the failures of Indian systems.
und dann die letzten Saetze:
With a price of £235, you can afford the great performance your scooter deserves, still at a sensible price!
Aber du hast sie doch wieder alle verarscht, oder?
Warum wolltest du nach Cambridge fahren? ;-)
Gruss_Soul
Jetzt hat es einen Namen !!!! Rudi !
Hier die ersten Google- hits , welcher mag es sein ?????
that with the name rudie is zwar a worthfull hint! but so full in ede zimmermann style, schleicht sich me the verdacht auf, that it is a fog bomb...
so i built the soko remod tonight. we hatten einen big success. we liftet the identy of this thousandsassa. by the way searchten wir & discoverten die homepage of this young lambretta nut. but before we give the announcement how du kännst find it, we have to thank all our informanten. the sachdienlichkleit of the bohrmachine-penis theory was the durchbruch: tatatatammm...
REMODS RELAUNCH NEOMOD HP
kann ich nicht so drüber lachen.
über derbe verkehrsunfälle, bei denen leute
was verlieren oder fast draufgehen kann ich 0,0 lachen.
sorry, da hörts auf.
<{POST_SNAPBACK}>
Das kann ich nachvollziehen, und finde das auch OK,
aber lachen musste ich trotzdem ...
Ich was mit einer Pm titled " Behave wie ein Erwachsener" gehitet !
- Halte die Assauer-theorie im übrigen für brilliant !!!!
@ steve:
jetzt reichts auch bei Dir! Solche "Späße" sind wirklich total unter die Gürtellinie und völlig krank. Halt Dich zurück, so gehts nun wirklich nicht!
Schadenfreude ist wirklich das Letzte. Sei froh das Du noch nie einen schweren Rollerunfall hattest! Weil ich wünsche nicht mal Dir, daß Du dich wie auch immer bei einem Unfall verletzt.
Wenn man im Glaskasten sitzt soll man nicht mit Steinen werfen, kapiert!!!!
Oh das Topic hat ein neues Thema " Sinnsprüche" . da bin ich dabei , dat find ich prima !!!!!!
- Wer in der Gummizelle sitzt, sollte die Finger vom Flummi lassen -
...,obwohl mich deine letzte pm emotional sehr stark berührt hat ! :-D
Ich würde vorschlagen eine eigene Rubrik mit dem Namen "total kranker und schadenfroher Kindergarten" zu eröffnen. Aber am besten Ihr sperrt diese kranken schadenfrohen Typen überhaupt mal länger raus.
Da würden so manche besten reinpassen!
Weil solange das GSF von solch einem Kindergartengeschreibe dominiert wird, ist es reine Zeitvergeutung hier überhaupt noch dabei zusein.
Wiedermal mo®dsmässig langweilig... gibts eigentlich keine Smilies die gähnen? Würd da gerne eines einfügen...
Fehlt eigentlich nur wiedermal der mo®dmässige Spruch im "Heul-doch"-Syle: "Wir Lambretta-Fahrer müssen ganz ganz fest zusammenhalten."
Nix is mit zusammenhalten. Es zählt nur wer mehr Pferde hat, ein längeres Rohr hinten raus und den grössten Ansaugschnorchel neben dem Batteriekasten :-D
... und ich hab keines von den dreien :-D
Ab damit in die Internet-Roller-Fahrer-Spielwiese F&S!
Edith kommt gerade aus der Küche und fragt " Was will der Rudi denn alleine in diesem Kindergartenbereich machen , da langweilt de sich doch ...?"
Bearbeitet von sukram
Wie kann jemand nur soviel HaSS gegenüber einem anderen Menschen (vor allem bei dieser lausigen Sachlage) entwickeln!!
EINEM MANN SEINEN PENIS WEGZUWÜNSCHEN!!!?!!! Was gibt es denn eigentlich noch niederträchtigeres, als einem ohnehin schon geistig minder bemittelten Mann seinen PENIS nicht zu gönnen!!!!?!!!! Also da hört für mich sogar die Ausrede: ?Das Christenthum? auf!
Auch wenn Brittania eine kleingeistige Vorstädtlerin war(ist), verstaerkt sich mit Steves Verhalten ihre Theorie(damals aus dem Relaunch-Topic) über seine ?Verfassung? ungemein. Sie bestätigt sie! Man wollte es erst so, nicht recht glauben.
Minder. Ganz minder. Boese. Ganz boese. Pfui
Wer da drüber lachen musste, gehört ebenso resozialisiert. Solch menschliche Wesen gehören quasi ?ge-relauncht?.
Remod: Bin ich froh das dass alles von deinem warmen Herzen abprallt :love:
Essenz: Fahr weiter das originale Luefterrad. Ausser du meinst die mit den Leichten verbundene Drehfreudigkeit passt dir hervorragend in Rudi-Hausen. Dann rüste aber konsequenterweise gleich auf 12V um und erspar dir die Umfrickelei auf 6V.
Gruss_Soul
Hallo Moderation - ab ins F&S !!!!!
2. Punkte noch - bevor auf dem armen Steve noch weiter gehackepetert wird....die ganze Schwanz-Geschichte hat wer anderes aufgebracht !
Und nur um das mal festzuhalten Soulist
....als einem ohnehin schon geistig minder bemittelten Mann seinen PENIS nicht zu gönnen!!!!?!!
für diese Beleidigung solltest du dich wohl beim Rudi entschuldigen, das ist wohl etwas harter Tobak...
MfG
    • https://www.kleinanzeigen.de/s-anzeige/vespa-ss90-race-replik/3060980966-305-2810   Ist das ein Nachbau / Replica von nem konkreten Vorbild oder einfach (wie geschrieben) "im Stil"? Finde ich ganz geil den Hobel.
    • Also müsste ich diesen Kabelbaum mit Schalter bestellen? https://www.scooter-center.com/kabelbaum-set-conversion-inkl-lichtschalter-bgm-pro-vespa-umruestung-auf-elektronische-zuendung-vespa-smallframe-v50-special/p-15383.html   Oder kann ich auch den Kabelbaum ohne Schalter nehmen und meinen jetzigen damit verbinden?   Dann noch die Frage ob der Kabelbaum von der Länge passt?
    • Eine deutsche Sprint mit Hersteller "Vespa" oder "Vespa-RSM" gibt es nur bis Baujahr 1963, mit Tag der Erstzulassung evtl. noch bis 1964/65 aber 1969 zweifle ich an. https://wiki.germanscooterforum.de/index.php/Herstellerschlüsselnummern#Deutschland   Der Nummernkreis, den Du da markiert hast ist der von den italienischen Piaggio Modellen, nicht deutsch. Die deutschen Nummern findest Du in der Tabelle darunter und diese beginnen mit einer führenden ☆35####☆     https://wiki.germanscooterforum.de/index.php/Vespa_150_Sprint_(VLB1T)#Baujahre_und_Rahmennummern_-_deutsche_150_Sprint     Nein, das ist weder eine 150 T/4 noch eine Sprint 150 aus Augsburg. Entweder hat der Herr Ingenieur bei der Abnahme oder die Zulassungsstelle hier einen Fehler bei der Vergabe der HSN gemacht oder beide wurden durch einen Dritten getäuscht.  Wie auch immer, die HSN ist nicht korrekt. Mit der angegebenen Fahrgestellnummer muss dort PIAGGIO (HSN 4013) eingetragen sein!   Vielleicht liegen wir auch alle falsch und es handelt sich um eine gut restaurierte italienische Sprint, bei der nur die HSN durch einen Verwaltungsirrtum vertauscht wurde. Mit den Hinweisen aus den anderen Kommentaren ist hier aber äußerste Vorsicht geboten!   Du hast die Optionen: dem "sympathischen Verkäufer" mitzuteilen, dass er den Preis deutlich im vierstelligen Bereich nach unten korrigieren darf. Dass er bitte mal das Thema mit der HSN aufklären soll, wer hat hier die falsche Zuordnung vorgenommen? Liegt für das Fahrzeug evtl. bereits eine Unbedenklichkeistbescheinigung vor? warten bis eine echte deutsche Sprint angeboten wird oder Du hier im Forum fündig wirst.   Solltest Du trotz allem den Roller kaufen, dann vor dem Kauf:  a) sicherheitshalber eine Eucaris Abfrage machen und  b) bau vor Ort zumindest den Tank aus und sieh Dir mit der Kamera vom Smartphone den Zustand von Tunnel und der Stoßdämperfaufnahe hinten genau an
