I'm going to build (and to have welded) a new manifold for my racer.
I have already TZR 125 reed valve, it's nice but just a little too big (height).
http://ktylife.free.fr/vespa/KTy133/KTy133Remontage2.jpg
And I want to do it *properly*... ;)
I'd like to have a look at the vForce(2) reedvalve block, but I can't find any physical dimension over the web !
Besides the dimension, what would you recommend for reed-block size for my Polini 133: KX-80 / CR-85 or CR-125 ? Are they similar ?
Sallih seems to prepare her engine with a reedblock that looks like a CR125 vForce... Can I have its dimensions ? :)
Thank you for your help and advices :)
KTy
Bearbeitet von KTy
the CR 85 has a 30mm carb.
the CR 125 has one with 38mm ...
I still feel sad, that we can't get the folks together to have a nice gearbox made :uargh:
So, again many people looking for a good deal on the Zirri one -
great. :uargh:
Blaster=RD=TZR within a few mm. Blaster vforce 2 is 52,5mm wide (in your case, high)
CR125 is about 60mm
Anything XX65-85 is smaller than Blaster, more Malossi-like
Tassinari has four different sizes which make sens using on a vespa, Mito-Likes (about 65mm), CR125-likes (bout 60), RD-Likes (52,5) and 80cc-likes. They only come with different stud holes to suit different manufacturers bore patterns.
Thanks for the carb size... Still looking for the reedblock size of the CR85 then :)
EDIT: Thanks Gerhard ;)
A friend of mine told me CR85/KX80 could be fitted on some 50cc derbi gearboxed bikes...
As for the Zirri short, yeah, it's sad... the problem is that not *that* much people want to spend 200euros for a short 4th... We'll see...
Bearbeitet von KTy
Sometimes I'm asking basic tuning stuff that I can't even answer myself... :D
For example, why would you want to have a bigger (wider) reedblock size ?
My only thought is that, for the same engine configuration (displacement and carburator), if you plug a wider reedblock, then the reed petals will bend less (for the same quantity of gazflow) compared to a smaller reedblock. Thus increasing maximum RPM because of higher resonance frequency...
Is this correct ? :-D
So, for my new reedblock hybridation, should I go for a CR125 / TZR125 one, or should I consider smaller stuff like RD350 ones or even CR85 ones ?
Discuss if you feel that's interesting ! :-D
Cheers,
KTy
Bearbeitet von KTy
Back on this old topic...
Actually, this time I just want to know if there are major performance improvements between VF2 and VF3 ?
Put in another way, is it worth getting the VF3, always a little bit more expensive than VF2... ?
Thanks,
KTy - :-D
