hello
i have 2 problems :-D( on my engine of my 200PX with PV1 side-car
the first one is when i want to sprint the engine starts to hold back like he is cholking when i start slowly it goes ok
the 2 problem is in 3 gear he will go 80km/h in 4 gear only 70Km/h and wil not go in his high Rpm
i have the folowing set up
200 engine with the inlet polisched
213 pinasco
23 t cosa cluth (i have tride a 21t but it will go in to high Rpm)
MCM race crank
JL left hand exhaust
4 gear of a 125 engine
ovelised SI 24 carbu with 135 jet
wide tyre 120 /90
thanks to al for helping me out
grtz sidvespa
take the 21 teeth clutch..some smaller back wheel and try out....
<{POST_SNAPBACK}>
Yes, If u want to stick to widetyre try 130/70-10, it has the same ratio as 3.50-10 about 7% smaller circumference than 120/90-10 :-D
It will make a hole lot of difference to the 4th gear. :-D
Best regards
Patrik Grann
Sweden
... I think a 60mm crank + rear tyre 3.50x10 or 130/70x10 and a standard exhaust or a racing pipe like the Taffspeed MK1, PSP, Swift, etc... could solve your problem. You won't need high rev',s the thing you'll need is torque...
ok thanks for the info
the first thing i did was change the jet back to a 116 this has ended the cholking :-D
the second thing i orderd a new tyre a 130 70 10 :-D
the cosa clutch 21 i have to try again when i have the time :-D to put it in in a few days i will have the key to our new house with a large garage :love: and i have to work on this also to keep the wife happy
sorry for my question but some of you don't understand that i live in belgium and over here there is a scootercene but it is not so big like in germany and we only have a few side-cars manly on a standard vespa or lambretta so i have no one else to turn to
grtz sidvespa
ps i will keep you posted when i change something and sugestions are always apriciated
Hi sidvespa!
I´m having a Px200e standard and a cozy sidecar, it works ok :-D , but not uphill :grr: . so i´m planning to use a 60mm crank and a 1,5mm headgasket for more torque and a 4th gear from 125 and keep the rest standard.
I have the same problem in Sweden, not many scooters with sidecar :-D and a house and a wife!
Have a nice summer! :-D
Patrik Grann
Not the same setup, but it might help
Rally 200 engine converted to PX 12v ignition using half casing.
Piston 70,4mm so gives 221 cm3
short 4th gear from a PX125
SI 24 carb, with 125 main jet, no autolub
Sidecar is a Cozy been clocked at 90 km/h in 4th.
You don't see many sidecar also in France.
Hi Lor@n
What kind of piston is that? :haeh: Is it used on a original cylinder?? :-D or is it a tuningkit? :-D
Best regards
Patrik Grann
Piston is used on an original cylinder.
When I bought it in FRANCE, it was advertised as a "230 japanese" conversion.
I've seen them on www.beedspeed.com years ago, don't know if they still sell them.
now i have f**k it up big time :uargh:
just blown a hole in the piston of my pinasco :-D( when i was getting the new tyre(130 70 10) so now it wil take some time before i can tel you about the changes i have made
first i am going to do the new house an them i will probebly put an other standard engine :-D in it the engine only needs a new crusefix and bearings :-D
grtz sidvespa
i think wrong jetting (to small)
i have drove the pinasco barrel alreddy a 1000 km with the O exhaust without problems and then put on the JL exhaust and dit it wrong with jetting
now i have an other question with an JL exaust and a O barrel shoud i change the timing or keep it the same as with the O exhaust
the mark A behind the flyweel
thanks sidvespa
Hi Sidvespa!
I think you should keep the timing as it is, and just change the jets if you are going to use the JL on the standard engine.
But I think you should use a colder sparkplug, NGK 8 or something like that and try it out!
Hi all you sidecar fans!
Why don´t you tell us none Germanspeaking scootersist about your engine setup???????? It would be nice to learn some more about what we need to do to get our sidecarscooters work perfect.
Patrik Grann
Sweden
and not very good at German language, but your beer that is the best in the world.
OT: Probably those who drive sidecars are not speaking english well enough or think they don't and are afraid of disgracing themselves. Be thankful for your very educational TV showing non-translated american movies. :grins:
Unfortunately I have nothing enlightening to say on topic. :-D
Hi there anyway :-D
Hi APO and thanks!!!
You might be right, but it´s to bad. My Enlish is far from perfect and it does not matter as long as people understand what one is trying to say.
Always nice with a answer :-D
Best regards
  • 10 Monate später...
Now I have got my engine work very well! :-D
Polini 208 with GS piston
MMW head
60mm race crank
1,5 mm footseal
Sito+
Cosa 23 clutch
SIP clutch relese shaft XT2000
17 degrees btdc
SI24
Just did the cylinderports, not the inlet port.
Not the fastest but good torque! ;-
hello
mine is also working fine now
the new set up is a bit like yours
polini 208
jl left
orig crank
23T cosa
24 ovelised si carbu
4t gear of 125
130 /70 rear tyre
engine is only the carbu inlet polised
timing 17°
1mm foot seal
for the top speed i have no idea yet i am driving it in the polini was lying on a shelf in the garage it only neded a new piston
grtz sidvespa
