Cylinder heads.
Juan Kerr
I am currently considering a new 'head for my Malossi 210.
I would just like to ask if there is any particular tuner's item that is regarded as the best,as at the moment it has a Malossi item. :-D
My choice at the moment is between;Worb5
Stoffi
PM tuning
Taffspeed
Anyone else I may want to consider?
The motor is a 210 unported barrel,cut crank with bottom end tune,30mm Dell'Orto,T5 'box with a P2 primary,Cosa 21 tooth clutch and a Taffspeed MK4 'pipe.
Thank's for any help. :-D
Bearbeitet von Juan Kerr
                                                      Stoffi
                                                      PM tuning
                                                      Taffspeed
<{POST_SNAPBACK}>
:-D;-);-) Well, I would say, you forgot to mention the very best of all: Gravedigger's GSF heads ;-);-);-) (THE gravedigger jumping around this forum...)
Bearbeitet von xsivelife
Okay,unfortunatley I can't read German on the link.
SIP list 2 versions,13013950 which look's a fairly standardish set up and 43322770 which appears to be a more centeral plug.I'm not sure which would be more suitable to my need's,any idea's? :plemplem:
Juan,
Please do it the easy way.
Buy an ordinary P200 Cylinderhead (or maybe even second hand !) from one of the shops (SIP / SCK) and get in contact with Gravedigger, and order a standard 1.1 GSF Kopf. You'll need to send it to him, and he'll machine it for you for around 25 Euro's (excluding shipment) and you'll get a fantastic cylinder head, with very good mid-rev power and no denotating problems ! Don't do anything else !
Just the best which you can get and it also reduces the famous Malossi 4th Gear problem.
AL
Harald, wird mal Zeit fur richtige Gravie-Kleber :-D
Thanks Al.
I contacted Gravedigger yesterday and he told me to seek out his MMW parts on the SIP site,I should have been clearer there.
Does anyone know if either of the item number's I listed previously are the 1.1 GSF kopf or are they differant models?
Thanks again.
    • Vielen Dank an alle! Ich habe mir am WE die Sache nochmal genauer angesehen. Es ist peinlichst auf den Verlauf des Schlauches zu achten, insbesondere auch im Hinblick auf den Hinweis von daeumilin, dass dieser unter dem Benzinhahngestänge verläuft, ansonsten reicht das Gefälle nicht für die ausreichende Spritversorgung aus. Nun passt alles und ich brauchte auch nicht den Sip fast-flow 2.0 verbauen, obwohl dieser mit dem dickeren Schlauchanschluss die größere Durchflussmenge bereits rein äußerlich nachvollziehbar macht. Grüße
    • Ich hatte vor einiger Zeit mal eine Cosa 23Z hier im Forum gekauft - leider war dann der Korb ausgeschlagen und die Sinterbuchse lose. Ich habe mich mit dem Verkäufer geeinigt. Kann wer von euch anhand der Bilder erkennen, ob es eine der späten PX ist?
    • Würde die schöne 125N bei 5-5,5k sehen.   Was schonmal gut ist, dass hier vom Spanier kein PX Motor reingefrickelt wurde. Wird ganz gern gemacht. Spanische Restaurationen können von nix bis gut sein. Lack und Blech schaut nicht Schlecht aus.
    • Es kann hier grundsätzlich kein pauschales Untermaß in der HZ Bohrung genannt werden. Bei Premium Wellen wo eine genügend hohe Zugfestigkeit und eine genügend hohe Härte in der HZ Bohrung besteht, reichen 0,08-0,085mm Pressmass. Hier wird auch im Bereich des Hubzapfen's das Material nicht ausbeulen.   Anders sieht es bei deutlich niedrigerer Zugfestigkeit des Materials aus, trotz hoher Härte wird teil's 12-13/100mm Pressmaß benötigt um eine gewisse Verdrehfestigkeit zu erreichen, die trotzdem nicht immer gegeben ist, aber hier beult die Wange im Bereich des HZ aus.
    • Auch noch gut sind die Spatel, die es zu nem Display fürs DIY Zusammenbauen gibt. Die sind quasi wie ein Schlitzschraubendreher, nur dass die aus Plastik sind    https://www.amazon.de/iFixit-Öffnungswerkzeuge-Kunststoff-kratzerfreien-elektronischer/dp/B072QLCN4T/ref=sr_1_6?__mk_de_DE=ÅMÅŽÕÑ&crid=N15YK8ZVJ2TS&dib=eyJ2IjoiMSJ9.DOLPDhsbQRdwCxD3L2WTIRIzN4waCt6ohhvR8mp7hYZEJlEfOjMgPKyBpd02pfAMgtwa7o7iVw__t5HoJ16XMO12-G9ovCZ0b_lRlmZuoP9aJIosvEckkryemY7PzKxFK3xHrkPDZZDhQgby529en4nisSFZqeHYlNpOVq1NQz8qpRl1gmQTjebGf1hwC4zqKxlkTzvtMypkAbN5Zrx88NjyywnlsUhygMRVZpSfEEg.EeVaV1A4F6gSdERZbtcGXo6G25MxDJzjpu6mg3YG8h8&dib_tag=se&keywords=spatel+handy&qid=1719911393&sprefix=spatel+handy%2Caps%2C79&sr=8-6   oder   https://www.amazon.de/Werse-Eröffnung-Werkzeuge-Kunststoff-Schreibtisch/dp/B07HBYZ5NW/ref=sr_1_8?__mk_de_DE=ÅMÅŽÕÑ&crid=N15YK8ZVJ2TS&dib=eyJ2IjoiMSJ9.DOLPDhsbQRdwCxD3L2WTIRIzN4waCt6ohhvR8mp7hYZEJlEfOjMgPKyBpd02pfAMgtwa7o7iVw__t5HoJ16XMO12-G9ovCZ0b_lRlmZuoP9aJIosvEckkryemY7PzKxFK3xHrkPDZZDhQgby529en4nisSFZqeHYlNpOVq1NQz8qpRl1gmQTjebGf1hwC4zqKxlkTzvtMypkAbN5Zrx88NjyywnlsUhygMRVZpSfEEg.EeVaV1A4F6gSdERZbtcGXo6G25MxDJzjpu6mg3YG8h8&dib_tag=se&keywords=spatel+handy&qid=1719911430&sprefix=spatel+handy%2Caps%2C79&sr=8-8
