180cc and 220cc with direct admission kit !?
Those are Pinasco "double carb" alloy barrels from the 80s: One carb sits on the standard inlet port on the engine casing and one with reed-induction on the barrel. Nowadays "hard-to-get"-items. But setting up the two carbs to work correctly must have been a real pain in the ass, also the throttle splitting system used to cause some trouble.
They used to be available from the German "rollershop" a long time ago. I have a catalogue from 1989, they used to cost 729 DM (approx. 373 Euros) for the 180 cc kit (including barrel kit, direct inlet manifold, reed block, Dell´Orto SHBC 20 L carb, air filter, jets, throttle splitter, throttle cables, Pinasco "carbon"-flywheel, primary drive, gasket set, 60 mm stroke crank, crank bearings). The P 200 kit included barrel kit, direct inlet manifold, reed block, Dell´Orto SHBC 20 L carb, air filter, throttle splitter, throttle cables, Pinasco manual in English language for 499 DM (approx. 255 Euros).
Bearbeitet von sidewalksurfer
My mate used to have a 177TI (twin induction) back in the late 80's,it was great fun but a complete pain in the arse to keep the carb's balanced. :-D(
I'm sure it would be possible to blank off the barrel mounted carb with a plate but I'm not sure if this would cause turbulance.Basically I wouldn't bother.
If you'd prefer to use a single carb set up I would recommend that you place it(presuming you already own it) on UK e-bay as they are very desirable for retro 80's street racers/customs.The Armando's Specials are becoming very popular again over here. :-D
    • Beschreibung: Suche eine ACMA mit offener Backe im Olack. Gerne auch was zum restaurieren Preisvorstellung: VB   [Bitte Durchlesen und anschließend den diesen Erklärungstext löschen, wenn ihr eure Verkaufsanzeige fertig habt]   Verbindliche Regeln für den GSF-Marktplatz ab September 2024 Wir bitten wir euch um die Einhaltung der GSF-Marktplatzregeln, insbesondere der P.O.R.N.O.-Regeln: Preis angeben! Inserate mit Auktionscharakter werden ausgeblendet. Ort angeben! (für Verkäufe) Selbst wenn ihr im Profil einen Wohnort stehen habt, der genaue Artikelstandort (gemeint ist die Stadt) ist Pflicht.  Richtig und vollständig beschreiben! Idealerweise mit Bildern, eventuelle Mängel müssen deutlich im Text ausgewiesen werden. Keine Links auf andere Verkaufsplattformen. Nur sachliche Diskussionen! Destruktives Runtersprechen von Anzeigen und Preisvorstellungen, Runterputzen und Stammtischgerede ist nicht erwünscht.   Ohne klare Eigentumsverhältnisse kein Verkauf! Der angebotene Gegenstand muss Eigentum des Topiceröffners oder der Topiceröffner muss durch den Eigentümer beauftragt sein, den Artikel im Auftrag zu verkaufen. Bei Verstoß gegen diese Regeln werden Inserate ohne Vorwarnung ausgeblendet, ebenso unseriöse oder grob unvollständige Inserate! Pro Mitglied und Rubrik (Biete/Suche/Tausche) ist nur ein aktives Inserat im GSF-Marktplatz erlaubt! Ausnahme: Für Artikel über €1.000 (z. B. Komplettmotoren) oder Teilesammlungen darf ein weiteres eigenständiges Topic eröffnet werden. Im Fall von Teilesammlungen jedoch nur, wenn diese ausschließlich en bloc zu einem Paketpreis über €1.000 angeboten werden. Hinweise für Inserierende Das pushen/hochschieben von Inseraten ist nur alle sieben Tage gestattet. Wenn ihr Infos nachtragen möchtet, macht das im Startbeitrag. Hinterlasst nach Abwicklung euer (hoffentlich positives) Feedback. Um Topics schließen zu lassen, ändert ihr den Titel im Startbeitrag auf "ERLEDIGT: alter Topictitel". Damit werden die Moderatoren aufgefordert, das Topic zu schließen. Allgemeine Hinweise Fair use! Wiederholungstäter_innen werden verwarnt bzw. temporär gesperrt. Achtsamkeit ist angebracht! Nicht alle Blechrollerfahrer_innen handeln redlich, anständig, und nach Treu und Glauben (gilt bei Kauf und Verkauf). Lasst euch stets eine verifizierbare Telefonnummer und Anschrift eurer Geschäftspartner geben. Schafft Transparenz, kommuniziert per Privatnachricht! Wann wurde überwiesen? Ist das Geld angekommen? Wann wurde versendet (Link zur Sendungsverfolgung)? Ist alles angekommen und im erwarteten Zustand? Der Betreiber des GSF ist nicht verantwortlich für die Richtigkeit der Angaben über die angebotenen Gegenstände. Wer private Geschäfte über das GSF abwickelt, gewinnt daraus kein Recht, die Plattform GSF für seine privaten Probleme, Strafverfolgung, Zeugenschaften und/oder Meinungsmache gegen Mitglieder oder Shops zu missbrauchen. Grundsätzlich sind dem Betreiber des GSF Realnamen, E-Mail- oder Postadressen nicht bekannt. Mit der Nutzung des GSF-Marktplatzplatz gelten diese Nutzungsvereinbarungen als anerkannt.
    • Servus beinander, hier wieder a paar Werkstatt-Tunes KTF! Roland
    • Was für eine Sollbruchstelle? Hast Du einen Link für mich?
    • Wow, da kennt sich aber einer aus...   Das BGM Set was ich gekauft habe ist folgendes:   Kabelbaum sollte dieser sein, da ich keine Blinker, keine Batterie und auch kein Zündschloss habe
