Enhanced spark energy For electronic ignition !
@Basti: What about "normal" road-city driving feeling (start from traffic-light, etc) ? Don't you feel the engine is better reacting at low RPM (<3000) ? Also, your idle rpm *should* be a bit higher :-D
The engine reacts with all of these. It´s not like a "new engine" but you can feel the difference. The enginge has 38000 km without a service :-D
Da sieht man den Unterschied evtl. etwas besser:
Mittelwerte:
Beste Läufe:
Basti
is wurscht, das poster bringt 1 PS
jo. einen echten prüfstand brauchts hier für ergebnise in dem kleinen bereich.
mines:
also kaltstart ist nun beim 2. kick - geeenial!
somit hat sich das teil allemal rentiert :-D
folgender gedanke:
ev kommts aufs lüfterrad draufan?
bei weniger magnetisierung bringt das ding mehr
bei mehr magnetisierung ev weniger spürbar
Thanks for these curves :-D
Correct me if I am wrong but looking at Basti's dyno curves, I have the feeling that the SM helps whenever the carb jetting is a bit too rich... For instance, at 5000 and 5500rpm, both torque and power is clearly better with the SM.
To confirm that, Basti, if possible, the next thing I would try is add 1/4 turn to your mixture screw and increase by 1 or 2/10 your SparkPlug electrode... Just to see if the theory match reality :-D
And once again, any chance to dyno between idle and 3000rpm with and without SM ??!
Bearbeitet von KTy
I build me the bigger ugly Sparkmagnifier like the one KTy postet in his tutorial.
I used an 1µF / 250VAC condenser and a 1N4007 diode. Assembled it all as you told us, connected as shown many times in this Thread and couldn't bring my px200 to start her egnine.
Without the Sparkmagnifier the engine starts at the first try. But if i connect the Magnifier back again there is no chance to get it running.
I assembled the Magnifier "perfectly" because im used to braze, especially those bulky tings like this Magnifier. I doublechecked that there is no short in the circuit and the connections.
My dear mr. singing club!
There is no chance that i made a mistake, but it won't work! I soldered some more Magnifiers to verify that. I testet 3 Magnifier on this Engine, took one to my Friend and tried it on his px200 and same thing here. It won't work.
How could this be?
My only clue is that i only used the 1N4007 diode and had no other to try. Could the diode cause this flaw?
Bearbeitet von TomDoe
Selbst, wenn du mehrfach geschrieben hast, das du den SM sicher richtig zusammengelötet hast: Bist du sicher, dass du die Diode richtig herum eingelötet hast? Die hat ja ne "Richtung"...
+1 Brosi :-D
Please give me the reference of your condenser and/or a picture, and additionally a picture of your complete circuit.
Are you sure your condenser is "non-polarized" ?
The 1N4007 is fine, I have tried it in the past.
Moin,
ja klar hab ich darauf geachtet das der graue "Balken" auf der Diode in richtung Kondensator zeigt. Wie auf dem Bild halt.
Eigentlich sind solche Lötgeschichten für mich wie für dich ne Flasche Bier aufmachen, deswegen verstehe ich das nicht.
Hier nochmal die Werte die auf meinen Bauteilen stehen im Detail:
Kondensator
A/R 46 MKP X2 SH
1µF 275VAC
40/110/56 C M
US 06LXA12
Diode
1N4007
MIC
Vielleicht ist da was faul?
Habe die Steckerenden auch durchgetestet, nicht das nur ein Stecker keine Verbindung hat oder solche Spässchen.
Habe auch gleich 3 Gerätschaften zusammengelötet um möglicherweise defekte Bauteile auszuschliessen.
Was mach ich nur falsch?
So you followed instructions here:
http://www.germanscooterforum.de/index.php...t&p=1288154
You paid attention to the connectors (picture 4)
And you are sure that you don't mess with the green wire coming from the stator and the green wire coming from the Kill.
The final circuit should be electrically equivalent to picture 2 in the first post: http://www.germanscooterforum.de/index.php...t&p=1072154
Can you give me a link to the condenser ? Is it from Conrad ?
I followed your instructions very exactly. I've never made a Mistake when it comes to soldering. The only thing i can imagine is that the parts are wrong.
I bought the parts from an electronic store in my city, i walked in gave him the partslist which i printed directly out of this Thread and got everything i needed.
I'm shure that i don't mess with the green cable, i tried both. :-D
Here is a picture of the parts:
Never say never :-D
Looks like the cap is fine, unless it is 0.1uF and not 1uF (there is a "dot" before the "1u"). Even in that case, it should work, I think (never tried).
What is the marking on the diode ?
Can you show the circuit once soldered ?
I am a bit clueless here ! :-D
It looks exactly same as this:
Im clueless here too and i never (oh, i won't use it any more :-D ) thought that i would get problems with this.
I've already managed to repair some Computer Mainboards with broken traces or capacitors, many damaged xbox360 with "red ring of death" syptomes (insider would know what it means) and i have often changed the backlitcolors of some cellphones back in 1999. I'm shure that i have done it right.
I would make some Pictures, but there is no chance that you can see anything cause i covered everything with hotglue.
There is no chance that i made the same mistake 3 times. I don't get it. Shit...
I'll try to get some right capacitos and try it again.
Shame on me, i didn't check the capacitors for the right values...
Edit: The Diode is 1N4007 MIC
Now that I look carrefully to both pictures, it looks like indeed your condenser is smaller than mine using the diode as a reference...
1uF / 250VAC is not *so* common. It can be quite big, depends on the brand / material used.
Let us know the outcome :-D
It is indeed a 275VAC could this be the problem? Shit, i noticed this now for the first Time. This little geeky electronicshop nerd tricked me very bad i think...
I will try to get the exact condenser some elsewhere. is it really so difficult to get those in germany?
Can you give me the exact partnumber from Conrad Electronics?
No it is not so "hard" to get...
Here are some conrad references that *should* work :-D
1uF - 250VAC - 400VDC (MKT technology): Artikel-Nr.: 500965 - 62
1uF - 250VAC - 400VDC (MKS technology -> Bigger size than MKT): Artikel-Nr.: 450192 - 62
1uF - 400VAC - 630VDC (MKS technology, overkill, but will work): Artikel-Nr.: 459837 - 62
Bearbeitet von KTy
  • 5 Wochen später...
ich war mit und ohne SM am Prüfstand
blau: mit SM
rot: ohne SM
Ohne SM etwas weniger, der Prüfer hat den Unterschied aber auf die stickige Luft in der Werkstatt geschoben, nachdem der Hobel den 1. Lauf absolviert hatte.
Keine Ahnung, ich hab den SM jedenfalls dann wieder eingebaut.
blau: mit SM
rot: ohne SM
Did you also notice better start and higher idling RPM ?
Strange that you loose some overrev capability :-D A bit lean ?!
Ich habe das Ding jetzt auch seit 800Km unter meiner PX .
Startverhalten hat sich leicht verbessert.
Man fährt aber sofort los, als wäre die Karre immer schon warm gefahren.
Das ruckelnde Drosseln am Ende jeden Ganges ist weg und geht in leises schnurren über.(fast kaum noch Vibrationen)
Zündkerze sieht gut aus, nur leichte Partikel haben sich drauf abgelagert.
Fazit : top Teil :-D
Hat jemand mal Probeläufe auf einem Prüfstand gemacht ???
Bearbeitet von tee
Ah, dann ist es jetzt ja amtlich erwiesen, das das Teil was bringt.
Erhöht sich eigentlich durch den besseren Funken die Temp. im Zylinder ? Sollte man fetter bedüsen ?
Habe dieses WE auch zwei Stück verbaut. Mehr Leistung???? Wenn, dann im marginalen Bereich. Gefühlt liefen die Motoren untenrum nen Tick besser, aber vielleicht wollte ich das auch fühlen weil es meine Erwartung war. Aber das Startverhalten bei beiden PXen hat sich richtig verbessert. Bei meiner PX war es bisher so entweder Standgaseinstellung optimal für warmen Motor, dann musste ich sie im kalten Zustand immer mit leichten Gas geben am Leben erhalten oder Standgas war so hoch eingestellt, das der Motor kalt nicht ausging, aber warm im Stand zu hoch drehte. Jetzt ist das Problem beseitigt. Konnte das Standgas eine dreiviertel Umdrehung zurücknehmen und sie geht kalt nicht mehr aus. Und die Vibrationen im Stand sind spürbar weniger stark.
Die PX von meiner Holden war ne klassische 6-8mal Kickerin im kalten Zustand mit Gespotze wenn man nen Tick zuviel Gas gab. Jetzt 2. Kick und der Motor läuft und schnurrt, als ob er gerade zwei Stunden gefahren wurde.
Somit :-D :-D
Werde meine Smallframe auch noch mit dem SM ausrüsten.
Frage: Fahre Kupferkerzen. Würde mit dem SM Platinkerzen Sinn machen???
Bearbeitet von hansenwernersen
Ich warte zwar noch auf meine beiden SM würde aber gerne schon mal wissen, ob es bereits Erfahrungen zum Elektrodenabstand gibt? Haben den alle ein bisschen größer gemacht und vor allem, was habt Ihr denn vorher für nen Abstand bei Eurer Kerze gehabt?
Hoffe, das wurde noch nicht besprochen habe aber nichts Detailiertes gesehen....
Bearbeitet von jan
    • Danke Dir , bin froh wenn ich dem Verkäufer Fakten vorlegen kann , denke er ist auch nicht undankbar darüber,Immerhin handelt es ich hier um einen Sammler mit 20-30 Modellen , auch Ihm kann da sicher mal ein Fehler unterlaufen sein . Aber eine Hülle und ein Scheinwerfer sagt nicht wirklich viel aus , ok nicht zulässig aber nach 55 Jahren kann auch schon mal was gewechselt worden sein . Heißt Planet Vespa das ich dort nur Asiatische Modelle her bekomme , ja gebe ich Dir recht ab Baujahr 1968 haut dass fast zu 100% optisch hin
    • Mit der BGQ und Schieber 6.0-6.5 würde ich die ND von 50 runterdüsen.
    • @GelbStich danke dafür ganzen Ratschläge , wie schon gesagt schweren Herzens werde ich mich mit den Gedanken abfinden weiter Ausschau zu halten . Aber so wirklich werd ich trotzdem nicht schlau daraus . Den Link mit der Fahrgestellnummer 03 …..für Augsburg ist einleuchtend , scroll ich aber diesen hoch kommt das Baujahr mit der Rahmennummer 09… VLB1 und laut Internet würde die 03… in Augsburg Hergestellt bis 1963 und danach nur noch zusammengebaut mit Teilen die beliefert wurden , daher dachte ich es handele sich dann um die oben angegebene Rahmennummern.     https://wiki.germanscooterforum.de/index.php/Vespa_150_Sprint_(VLB1T)#Baujahre_und_Rahmennummern_-_deutsche_150_Sprint
    • Wohnmobil ist gepackt, war nicht sicher ob zwei rein gehen, funktioniert wunderbar.  Fahren erst Bardolino und dann nach Elba, sehen uns.
