Wie in der Formel 1, gibt es angeblich für Berten und Fespen:
http://cgi.ebay.co.uk/Lambretta-Carbon-Fib...1QQcmdZViewItem
Lambretta Carbon Fibre Clutch Plates
The long awaited Carbon Fibre clutch plates to suit most Lambrettas are now available to order. As many of our customers will already know, none of our products are mundane and we are always striving to improve the scooter scene with new products. The Vespa Carbon Fibre clutch plates have now been in use for over 20 months with excellent results and great feedback.
The clutch plates are 3.4mm thick and will suit 4,5 and 6 plate clutch baskets, the material has been used in super bike and rally car applications for years, so the (Carbon Fibre) has some pedigree. The plates are far stronger than its predecessor, for this fact alone, should make the plates good enough, but the use of carbon fibre material has added benefits as well, which include; the use of a brand new oil to the scene - Mobil 1 Racing 4T fully Synthetic (never before has a Scooter engine been able to make use of Superior engine oils). We are that impressed we have switched our 2 stroke to Mobil 1 Racing 2T. Brilliant engine protection from racetrack proven oil, in addition only 5 to 10 minutes pre soak time before installation, unlike the 24-hour standard cork plates.
These plates work fantastic in both modified and unmodified scooters, but for those of you who like just a little more power, then these plates will give you just that, without any clutch slip or drag. Modified Lambretta?s have had clutch problems for years and have not been able to use the full potential of the horse power capability.
Carbon fibre is the answer!!
Scooterists who choose these plates will not be disappointed.
This product is only available from Sparkright Technologies
Braucht manN das dringend? Oder ist das schon theoretisch bretrachtet von Haus aus Schmarrn?
Ja Lummy, das kannste dir doch ausrechnen, für 60 Euro bekomme ich bei LTH 4 Sätze Scheiben, nachdem das rutschen ( wenigstens bei mir) vorbei ist kann man ja sehen wie lange son Satz Scheiben hält, das mal 4 und ich habe die Einsatzdauer die diese Carbonscheiben übertreffen sollten. Das wiederrum kann ich mir gar nicht vorstellen, denn nur weil der Belag verändert wird hält das Trägermaterial "Stahl" ja nicht länger als bei normalen Scheiben, heisst also das die genauso ausschlagen und deswegen irgendwann getauscht werden müssen.
Wers hat . . . .
- gonzo
