Unnötiger Mumpitz. Originale Piaggio Beläge tun es mit reichlich Qualm am HiRa auch. Bei Verwendung eines S&S CNC Korbes schlagen nicht mal die Laschen aus. An ausgeschlagenen Laschen im Blechkorb sterben die Beläge sowieso bevor sie verschlissen sind.
Works perfectly and absolutely recommended. I've had several clutch problems earlier and this was tested on the dragstrip as well as on the street. The clutch engagement is smoother and the clutch grips more firmly.
Well if one use the clutch with standard cork plates softly they will last as long. But what is the use with a highly tuned engine when you can't release the power at start?
The clutch basket has nothing to do with this. If have both 16 spring and 8 spring cosa clutch and think the carbon plates is a great improvment. I bought two sets and a mate bought on set for his street scooter and I think the the previous one week hard clutch use wear out will be abandoned with these plates.
This is a nice upgrade and if you already spent alot of euros on a CNC clutch these plates are cheap in comparison for the amount of advantage.
cheers
Truls
PS! The plates are not made of any harder steel than original and will fit perfect in the clutch basket, unlike some pirate plates that one of the bigger german shops are selling.
Stimmt. Meistens ist der Belag das Blech darunter nicht wert.
Arschbrand hat wohl recht, oder soll bloß
Carbon = Megageil??? :uargh: einen hohen Preis rechtfertigen???
Eigentlich kenne ich Carbonbeläge nur aus Trockenkupplungen, ist in einer Duc oder SM ein geiles Gimmick auf'm Track, unbedingt brauchen tun's aber wohl nur sehr sehr wenige....
da habt ihr natürlich recht das da eher das metall der scheiben flöten geht,
aber was tun wenn die kupplung rupft? könnte mir vorstellen das die carbonscheiben weicher greifen, oder so ähnlich. :-D
The way the clutch basket on the picture is reinforced (position of the ring, way of welding) doesn't fullfill me with trust into their announcement. Therefor:
Which concrete clutch-problems did you have that were solved by the carbon plates? And: On which clutch (number of springs, strenghtened or original springs?)
If a clutch doesn't grip firmely, I'd say it is lacking springs. So in my opinion the only point for carbon could be that it enables you to use less (8 instead of 16) or less strong (standard instead of strenghtened) springs. Would you say so?
The problem that the plates didnt even fit into the basket. Plates sold by SIP. The carbon plates fit perfectly.
The problem that the cork on the plates do not stay on the plates for quite long. The cork is too soft and shallow compared to the carbon.
This was with an 8 XXXL spring cosa.
I have also a 16 spring for my street scooter and the carbon plates will fit into this when the other wear out.
I don't agree on this one. This has to do with the friction between the plates. Harder springs only bring up the friction force. And if the friction force is too high the clutch start nugging, and will be more difficult to engage smoothly. This I experienced with my 16 spring cosa using 16 taffspeed springs.
I only share my experience with the carbon plates, people are free to try it if they like. But to make a conclusion upon a first impression I think is uneccesary.
Well, yes. But that doesn't answer my question. With the reproduction-shit sold by sip you certainly always have problems. But I think noone with a properly tuned engine uses those. So the question is: what's the advantage of the carbon ones compared to original ones (which fit properly)?
I totally agree. That's why I asked. But anyway, enough said. If this subject was discussed several times already I'll find answers via "suche".
Hallo, mal ne dumme Frage:
Könntest Du eventuell die Bedienungsanleitung: Posting (A guide to the features avaliable when posting on the boards) von englisch in deutsch übersetzen und hier reinstellen? Mein Englisch ist nämlich nicht besonders gut. Für Dich wäre das doch kein Problem?
Vielleicht steht die deutsche Übersetzung auch an anderer Stelle und ich habe es nur noch nicht mitgekriegt?
Danke erstmal, Don.
    • Danke für die Rückmeldung.    Ich bin jetzt ~15 Jahre ein vollsynthetisches öl von Total gefahren. (hat immer gut funktioniert. Auch die Enduro lief damit problemlos) War immer günstig in der Bucht zu bekommen. Kürzlich bin ich aber auf Motul 710 umgestiegen.    Was genau meinst du mit dem ZZP? Ich habe die Zündung "auf statisch" gestellt und auf 18Grad abgeblitzt.  Zündkurven habe ich verschiedene getestet. Die meiste Zeit bin ich 2M gefahren. Habe ich gerade nochmal nachgeschaut.    Genau. Ich bin 178 (Polini) gefahren. Falschluft schließe ich aus. Ich habe den Motor abgedrückt und auch mit Lecksuchspray abgesprüht. Nach dem Ausbau war er auch ziemlich sauber. Nur die Getriebentlüftung hat ein bisschen raus gesifft.    Woran machst du das fest, das der Motor zu mager lief? An dem kleinen knick nach unten zwischen 8500 und 9500rpm auf dem Diagramm?    Hier sind nochmal Fotos von der anderen Seite des Kolbens.
    • Hab gerade schonmal das Riffelblech raus gekramt, da kann man schöne Dinge draus bauen...  Braune Sitzbank und Weisswandreifen sind im Zulauf!
    • Servus  Ich möchte die ZGP einer PK s neu verkabeln. Sie hat 6 Kabel: weiß, rot, grün und blau, schwarz, grün im Multistecker.  Leider hat der Vorbesitzer irgendwelche Kabelfarben verwendet und ich bin mir grad nicht sicher.    Hat jemand die Belegung bzw. Positionen der Kabel an der ZGP zur Hand?    Besten Dank
    • Sehr schön, gibts denn die Masse der Backen irgendwo? Ich hab beide mal nebeneinander gestellt, die sind beide gleich hoch d.h dass dann wohl beide falsch sind..
