I'm looking for some pics/topics about the mountting of the sensor on the fork and of the magnet on the rim .... with a grimeca disc brake .... :-D
Bearbeitet von Luccio
ok but how are they mounted ?
the magnet is welded on the rim ?
what about the sensor ?
You can use epoxy to fix the magnet. for the sensor i took "hot-melt adhesive" (in german "heisskleber").
thanks !
for the sensor you use this type of hot-melt adhesive ?
jep. and it was very cheap, so nothing special.
I get not used with such a cheap german mecanical mounting.... :grins:
I was expecting someone do a special part with a metalsheet or somethingelse.... :wasntme:
