Sorry to ask again, but I cannot search the forum, I don't know why, I 've an error...
How do you drive a 100/80-10 tyre ? Can you mount a cosa rim on a smallframe ?
Is the "special 100" from SIP a good alternative ?
I tried with the standard rim, it works, but the tyre is a bit too pinched...
Thanks !!
I ride a 100/80-10 Raceman on a Cosa-rim on my Smallframe.
I had to put two washers between rim and brake drum to get it away from the engine case.
Not fine, I know, but the rim is still centered by the brake drum.
Another possibility would be to ride the wide part of a 2.10 rim and the slim one of a Cosa-rim. That would fit without spacing and is at least 2.30 wide.
Greetings, jan
I ride the same tyre on the same rim
Sorry... Are you talking about an original rim or the cosa rim ?
And I have also a straigth spring from SIP/worb5, so there is clearance issue from this point.
What about putting 10 x 1 or 1.5mm washers *between* the two half-rims ?? :plemplem:
I ment the Cosa rim and the Schwalbe Raceman tyre.
I can take a picture of the tyre where you can see the distance between rim and clutch cover.
Why do you want to put washers between the 2 halfs of the rim? For what?
Take the Cosa rim and put 2mm distance between rim and brake drum.
If you want to, you can take washers for that.
