The skirt of my Polini 177 suprisingly :-D broke !! :-D
1. The question is, can I put a DR on my cases that I have enlarged to fit the Polini ?
2. Can I work the DR so that it has the same base as the Polini ?
3. DR + Polini head is better than original DR cylinder head ?
Last one, :-D
4. Can someone give me a link on the topic discussing the DR tuning ?
KTy :grr:
Last one, :-D
KTy :grr:
try this:
http://www.germanscooterforum.de/index.php...c=52300&hl=
http://www.germanscooterforum.de/index.php...44&hl=dr135
a guy calles dr177(!) has lots of links in his signature too...a bible.
Last one, :shit:
KTy :grr:
Hi, KTy...
I´ve done my DR like the Polini, or to be honest, a "little" bigger ( :-D :wasntme: :-D ) with grinding 8mm from the bottom and a put packing plate under to open the channels complete (oder wie die ÜS auf Englisch heißen mögen...)... :-) In my opinion, you should open the DR-channels with a grinder like the 177 Polini or even bigger like I´ve done... And yes, it´s a good alternative instead of the Polini... And yes too, read the topics from dr177... :-D In my opinion with a Malossi valve and a 28 or bigger PHBH or Koso and a TFF or PM it´s a good all day runner with enough power and, I think, about 18-20 hp+ at the backwheel, but if you done this, it´s not a silent sleeper coz the valve and the exhaust if you know wot I mean... :-(
Off the package a DR is not more than a good base I think...
The Polini head is much better than the DR head (1:10,6 instead of 1:8,6 conmpression ratio)... But you can grind the DR head about 1 to 1,5mm down like I´ve done on my engine
An alternative for you to read: read it on www.freakmoped.at or so, o.k. it´s in german but there are some photos... :-D
Thanks... www.freakmoped.at doesn't work right now... :-D
The engine is PX125 cases, with 22/68 primary, 8" wheels (!), Leo pipe, racing crankshaft, Polini manifold + 1mm spacer and PHBH28...
It was a *blast* with the Polini 177, unfortunatly, I seized 2 times because of the carb-manifold rubber that has an hole :-D And then I discovered the skirt was broken !! :heul: :-D
By the way, an opinion on the Malossi 166 ?
