topic
uhu endfest for example
Thanks man.
I read and was told about the Weicon Titanium as well, informed and found a shop around my city!
Hopefully my Pinasco 225 will like it :-D
ps. you're going to have another PM :shit::-D:-D:-D
Hello,
I tried the Titanium. For that kind of repair it was not quite good.
I wouldn´t use a repairstick. You should better use liquid products like UHU Endfest(up to 300 degrees) or Delo Metalix(up to 180 degrees)
Hello,
Hi T5Langhuber,
thanks for the participation.
I looked into UHU internet site and seems that if you put the product into the oven than it holds much more!
Maybe I should get them both and use the Titanium to close lateral transfers and the Uhu for the drehschieber surface... mmm...
Do you have to clean and work the surface for the Uhu to hold better?
regards,
Matt
Hello,
for the lateral transfers i used the titanium too. For that it is really good, i think, because it it resitent against oil, gas, ester. etc...!
My Delo Metalix works even quite good in my T5 engine.
First you schould grinding the surface a little bit with the dremel. Then i use "Aceton" to clean the surface.
By the way the titanium need about 72 hours to get 100% firmness. But you can use ist afther 8 hours.
Here is the datasheed, unfortunately in german, but you can see on page 4:
http://www.weicon.com/de/download/prospekt...pair-Sticks.pdf
Bearbeitet von T5Langhuber
yes sir. a friend of mind did a crazy thing with a piston on that way
and it works :-D
Good! :-D
Practically this is it:
Setting:
The setting time depends on the temperature; final strength can be increased by applying heat (not over 200°C ? see table).
Temperature Setting time Strength
20 °C 12 Std. 1200 N/cm2
40 °C 3 Std. 1800 N/cm2
70 °C 45 Min. 2000 N/cm2
100 °C 10 Min. 2500 N/cm2
180 °C 5 Min. 3000 N/cm2
I was told that the adhesion of Devcon F is 2600 PSI and for Devcon Titanium 2000 PSI (better wear resistant). I'm no good with conversions but that should be around it...
Definitively gotta try the oven thing... :-D
Regards fellows,
Matt
    • Hier ist zumindest eine lenkkopfabdeckung dabei. Wenn auch vermutlich kein ganz guter Zustand. Vielleicht hilft es ja.    Gerade bei #Kleinanzeigen gefunden. Wie findest du das? https://www.kleinanzeigen.de/s-anzeige/vespa-px-teile-zu-verkaufen/3012900293-223-7404?utm_source=copyToPasteboard&utm_campaign=socialbuttons&utm_medium=social&utm_content=app_ios
    • Machst du dann für jeden noch eine Zusammenfassung a la Herzblöd äääh Herzblut äääääääh Herzblatt 🥰?    „Wer soll jetzt dein (unser) Herzblatt sein?   Humma? Der Neu-Kettenmoped-Fahrer, der jeden mit seinem Anhänger in der Not mit Bier versorgt, dabei gleich noch einen Strafzettel vorsorglich ausstellt und dann alle mal stramm stehen lässt? 😅   Oder Spider? Der mit seinen langen Fingern in jede Ecke einer Smallframe vordringen kann, dabei noch hilfreiche Tipps ins Forum diktiert und einmal die Woche ne leckere Pizza für alle serviert? 😀     (zu den anderen potentiellen Modells ääääh Mods kann ich nix doof dichten, da ich sie nicht persönlich kenne). 😎
    • Ob das die Dachpappe so geil findet ?
    • Probier's aus und berichte:) Hab anfangs auch die proma Banane drunter gehabt. Mit den Standard Steuerzeiten und 3.00 Getriebe ohne kurzen vierten, war das ein Sprung vom 102 polini   Der Auspuff selbst. Keine Ahnung. Viel kann man nicht erwarten. Die Dexter jungz haben sich aber sicherlich was dabei gedacht. Tue es!  ausser du willst den reso Kick.
