Alloha,
I have a small question for you Lambretta's guys :D
Is the electricity for ligths on a lammy AC or DC ? What is the most common ?
Can you find AC current near the handlebar ?
Strange questions... :-D
KTy
the lights (front and rear) are always AC. Most models were available as DC and AC versions, depending on the country where they were sold. On the DC versions ony the parking light, brake light and horn were powerde by DC.
the spanish Lince with Motoplat ignition / generator ist totally DC. :wasntme:
Okay, that's what I wanted to hear ;)
So, the rest has AC ligths... :-D
Thanks :-D
Bearbeitet von KTy
it's a bit hard to figure out what you actually want to do. if you need to convert your electrical system to DC then you might want to check www.scootercenter.com as they have a regulator now that supports AC and DC from the output of a regular electronic ignition. and you can choose to not us the AC part of the current - and have an all DC wiring if you so please.
OK now drop the bomb and tell us you're installing a sound system. way cool.
Alrigth,
I will be doing in the near future a prototype for a simple and easy to use RPM counter with a small LCD display, with the possibility to plug an EGT sensor, a CHT sensor and speedo input. It will powered on the AC light, no battery, few wires... vespa/lambretta/whatever.
Schuss, :-D
When you have AC electricity, it's easy to know the RPM of your engine ;) :-D
like the rev-counter of Vespa T5 and old Hercules? They are not soooou precise. :-D
I don't exactly know how they work, but the T5/Hercules is probably analog electronics. I will do it digitally, that means that I will "simply" count the number of waves per second, taking into account the number of coil of the stator. Exactly like the GSFDyno by Atom007, I designed the latest interface circuit, the error will be near to zero....
By the way, I'm pretty sure it doesn't really mater for you if you reach 9566rpm or 9563rpm, rigth ? :-D
This project is a really simple circuit and the software is also easy to write, I just need some more time... :grr:
Bearbeitet von KTy
you haven't got so much time dear: time is money! hurry up. I'm highly interested :-D:shit::-D
    • Da es mir aktuell einfach zu kalt ist, kann ich ehrlich gesagt noch nicht viel dazu sagen.    Der FastFlow ist drin, Filter ist keiner zwischen und Schlauch auch sehr kurz.    Joa, mag sein. Aber ich teste gerne.   Tankdeckel entlüftung nichts geändert, deshalb sehe ich da ehrlich gesagt keinen Grund zu suchen, da es mit dem Keihin wunderbar funktionierte.   Und dass ich für mehr Leistung da woanders was machen muss ist klar, ich möchte aber dennoch einfach ein bisschen rumprobieren.
    • Bei dem Setup und Auslegung machen derart große Vergaser keinen Sinn, sogar eher nur Nachteile.   Thema Pumpe: Nutzt bei einer SF kein Mensch. Entlüftung im Tankdeckel prüfen und fixen. Das sind unnötige Baustellen.  Wenn du Leistung finden willst musst du an anderen Stellschrauben drehen.
    • Handgeschabte Spätzle mit Rahmsauce nach «Stroganoff Art».
    • Ja, ich habe jetzt eine 3.72 Primär eingebaut (Die hatte ich noch übrig). Das ist zwar eigentlich ein bisschen zu kurz für 102 aber es ist ja ein 50s Getriebe mit langem 4. Gang. Mal sehen, jetzt sind vielleicht die ersten Gänge ein bisschen kurz aber dann passt es im 4. Für zum Bäcker fahren oder mal zum Baggersee wird es reichen
    • Mein Gruß in die Augsburger Runde. Als wideframe Neuling habe ich mich nach diversen Largeframes mal an eine Augsburger GS/3 herangewagt. Das ganze ist noch im Entstehen, soll vom Konzept her das Fahrzeug in das neue Jahrtausend bringen, dabei aber möglichst original aussehen. Das heißt Motor, Fahrwerk, Reifen, Bremse, Elektrik und so weiter sollen schon bestmöglich sein. Motor wird eine Quattrini M1XL Conversion. Jetzt kommen wir zum Problem: leider gefällt mir die original Sitzbank überhaupt nicht und ich suche eine schnittige Alternative. Bestellt habe ich jetzt die Ancilotti vom SCOOTER CENTER. Die passt aber leider sehr schlecht, steht vorne zu weit über, hat zuviel Spalt, der Tankdeckel stößt an und so weiter. Welche Alternativen Sportsitzbänke habt ihr auf euren Kisten so verbaut? Die streamline für GS kenne ich, die Frage ist wie gut ist die Passform in der längerfristigen Praxis. Lohnt sich das Geld oder gibt es andere gute Lösungen. Vielen Dank für eure sachdienlichen Hinweise...
