Now 121 persons preregistered, that isnt bad 1 month before the run!
We expect not more than 200 scooters, but hell we´ll have a good time!
If you dont like the though about ferry and riding, there is always a plane to take for the sore butted!!
Check out www.norwegian.no
More than 150 preregistered, 29 degrees and sunny, 3 bands and loads of dj´s booked. First Germans arrived at 23.45 last night.
Now we are ready for a good weekend!
Check this space later for pictures etc!
Moin,Moin,
again one of the best and relaxed Runs i've ever had (exept the way back to Gothenburg)!
Thank you Frank`N`Stein
Nice to meet all of you guys there again!
Happy to meet lots of new faces - special greetings to silver-babe!
Pics and movies will be oploaded right here.
See you in Gjörvik `08!
Regards
Helge
Hi to you polish bastards!
Very nice to see you again, even if I had to work some and would have wanted to chat with you more than I did !
Heres some pictures to enjoy:
http://foto.aftenposten.no/show_album.php?aid=1483050
http://www.flickr.com/photos/svint1/
http://www.alexandertufte.com/csrpanorama.jpg
http://www.alexandertufte.com/csr/
Did you manage the way to Gothenburg without any break downs?
Stein
Moin,Moin,
Regards
Helge
Of course not! But this is another story....
We all got on the ferry in time, thats what counts!
Thank you and your team for the great time we had!
btw, Stein, or anyone else, do jou have a ranking about the gymkana? it would be interisting if I bet Christof aka Mc Gywer....
best wishes for your family!
Marc
    • Auch der Innenzug? Dann hilft nur stochern mit etwas was flexibel ist aber dennoch steif genug um um die Biegung im Beinschild zu kommen. Bisher hat bei mir da eine dickere Angelschnur aber auch schon mal ein Kunststoff-Einzugsdraht für Elektroinstallationen geholfen. Vielleicht klappt aber auch ein entsprechender Draht oder ein dicker Zug. Ums Stochern und wenn Du hast Kontrollieren mit einer Kamera/USB-Kamera wirst Du aber nicht herumkommen. Vielleicht, aber auch nur vielleicht durch Verlängern und "Mitnehmen" von einem Schaltzug bis zum Punkt von der Gaszug separiert werden muss.  Lenker ab und Hupe raus wird auch sein müssen.
    • toyota corona ist vorbei schafe sind gerne eingeladen !
    • Wie ich so mitbekommen habe ist es für die Lebensdauer von Klimaanlagen nicht schlecht, wenn die zwischendurch auch mal abschalten können.   So Tage wie heute sind optimal für die meine Konstellation. Draussen bei 22° (im Schatten) war der Raum schon wieder auf 26° aufgeheizt. Ja sogar heute morgen mit 18° außen schon 24° innen trotz offener Fenster. Die Hitze steckt noch in den Wänden, es kommt aber keine so extreme Hitze von außen mehr rein. Da arbeitet die Klima dann eben 90 Minuten, kühlt den 25m² Raum auf Wohlfühltemperatur herunter und schaltet dann immer wieder aus und ein.   Mit 9000 BTU hast du ja rund 30% mehr Leistung. Dann muss die nicht durchgehend arbeiten wenn du eine realistisch erreichbare Zieltemperatur einstellst. 7000 BTU sind schon echt wenig, aber trotzdem besser als nichts. Meine neue Midea hat auch 9000 BTU. Die wird dann im geschlossenen 16m² Arbeitszimmer eingesetzt werden.   Mit dem BTU Rechner kannst du ja mal nachrechnen, ob sich das so wie gewünscht ausgehen könnte -> https://klimaboy.de/sections/klimaanlagen-rechner/klimaanlage-btu-rechner/ Der berücksichtigt auch Deckenhöhe, Dämmung, geographische Ausrichtung, Verbrauche wie Personen im Raum und elektrische Geräte.   Ich habe mich für eine durchgefärbte 3mm Acrylglasplatte entschieden. Mir gefiel das hohe Gesamtgewicht bei 5mm nicht. Und in 4mm gab es die durchgefärbte Version nicht. Die Scheibe ist weiß (reflektiert also Strahlung), ist spiegelnd (sieht also hübscher aus [subjektiv]), und hat eine Lichtdurchlässigkeit von nur 3%. Meine getönte Scheibe die ich zur Zeit verwende hat im Vergleich dazu eine Lichtdurchlässigkeit von 60% (s. Bilder oben).
    • Hm....       Ich fühle mich übergangen.       ...bin aber trotzdem dabei
