I have rebuilt my PX 125 Arco (=Lusso), changing almost everything, bearings, oil seals, ...etc
I have very very few power at low rpm, and then, around 3000rpm it is fine. For example, in 1st gear (!!), if I instantly open full throttle then it will take maybe 2-3s to really start pushing ! :-D:-D
I have an idea on what is going on... :-D But I hope I do not have to open the engine again... :-D
Because I had to change my crankshaft, I put an original piaggio, in good condition, BUT home-made cut (16mm).
Could it be the problem ? :-( If so, how can I change the jetting so that it works fine at low rpm ?
I have standard jetting: idle 140/45 and main 140/BE5/100 ...
By the way, is there a toric seal on the mixture screw of a standard SI20/20D ? I thought there were one... :-D
If it is not the problem, what could it be ?? :shit::-D:-)
Thanks... :cheers:
Bearbeitet von KTy
Since the crankshaft is the only change you`ve made, I guess that that's the problem: You might have heavy sprayback at low revs which causes your engine to not accelerate properly.
As far as the jetting is concerned I think it should be fine (at least roughly). What's a toric seal? At the back of the "cover" around the carb were the screw comes out there's a little rubber seal, but I think that it's more or less intended to keep the dirt out- it won't affect your carb settings if not fitted.
On my SI20/20D, I have this kind of mixture screw:
I was wondering if there is an O-ring... ?
I'm going to check the ignition... :-D :-D :-D
Sure? exactly this mixture screw?
As far as i know is this one only for the SI 24/24 G (for the T5)
The original one for the SI 20/20 D looks different (for screwdriver use).
Usually the T5 screw shouldn´t fit on the SI 20/20 D...
This could be a reason for your Problem.
greets,
Jan
There is two versions of SI20/20D... :-D
An "old" one than comes on Sprint for example as a mixture screw that looks like a normal "screw".
Newer SI20/20D (PX Lusso for example) has this kind of screw and this is logical: They have an electric-start !
Anyway, maybe I'm a bit confused :-D with dellorto PHB series that have a little washer and an o-ring. (Parts 19 to 22 here)
Could an old exhaust gives the same results ? (low power at low rpm and normal power over mid-rpm ??)
Could also be that the petrol-air mix needs to be richer now due to the longer inlet phase- try a bigger idle jet maybe and a BE3 instead of a BE4 (don't know the english word for that jet, its the one you stick your main jet in).
arrow on piston crown pointing to exhaust port? :-D
Unfortunatly no...
low-mid to high rpm the engine is just very good ! Besides that, I drove 200-300km, I doubt the rings would have survived if I had reversed the piston ! :-D
One of my buddies drove over several weeks with a reverse installed piston
until he realized it... by the way, that was a T5 cylinder.
So, don't be too sure
